[mapserver-users] Itemquery problem
Matthew Hatcher
MJHatcher at space.qinetiq.com
Thu Aug 1 06:47:06 EDT 2002
Hi all,
I'm having problems using the itemquery mode of Mapserver 3.6.1. I'm wanting
to have a text box which the user enters a postcode, which then queries a
shapefile containing postcode points. This then returns a query map of that
area. At least to start anyway.
Whatever I do and whatever is entered, itemquery returns the first record,
and itemnquery returns all the records.
What am I doing wrong? Any help would be appreciated, especially if it
includes examples of how to do it right!!
Matt Hatcher
<-- test.html -->
<html>
<body>
Enter postcode:
<form method="get" action="/cgi-bin/mapserv.exe">
<input type="hidden" name="map" value="test.map">
<input type="hidden" name="map_web_imagepath" value="\Inetpub\wwwroot\tmp\">
<input type="hidden" name="map_web_imageurl" value="/tmp/">
<input type="hidden" name="program" value="/cgi-bin/mapserv.exe">
<input type="hidden" name="mode" value="itemnquery">
<input type="hidden" name="qlayer" value="postcodes">
<input type="hidden" name="item" value="PCODE">
<input type="hidden" name="mapext" value="shapes">
<input type="hidden" name="buffer" value="1000">
<input type="text" name="value" size="10" value="">
<input type="submit" value="Go!">
</form>
</body>
</html>
<-- test.map (the relevant bits!) -->
QUERYMAP
SIZE 300 300
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
LAYER
NAME "postcodes"
TYPE POINT
STATUS OFF
DATA postcodes
TEMPLATE "query.html"
FILTER "PCODE<>''"
CLASS
COLOR 192 192 192
SYMBOL "circle"
SIZE 3
END
END
<-- end -->
The information contained in this email and any subsequent
correspondence is private and is intended solely for the
intended recipient(s). For those other than the intended
recipient(s) any disclosure, copying, distribution, or any
action taken or omitted to be taken in reliance on such
information is prohibited and may be unlawful.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020801/c99a7a4d/attachment.html
