[mapserver-users] Installation problem on FreeBSD
Lowell Filak
lfilak at medinaco.org
Thu Aug 1 08:27:36 EDT 2002
If you can set the environment variable 'MS_ERRORFILE' in the webserver to a file name that can be written to by the userid the process is running as the file should show additional information regarding what the actual error is.
Lowell F.
The following message was sent by Franziska Wenzel <fw at urbanix.de> on Thu, 01 Aug 2002 11:39:39 +0200.
> Hi there,
> I successfully compiled mapserver on my own MacOS X
> System, no problems and everything works fine.
> But I have problems on our hosted webserver.
> Its running FreeBSD 4.1.1. and compiling mapserver 3.6 seemed to work fine.
> But when I try to run the demo, mapserver shows an Internal Server Error
> When I look at apaches error log it says
> Premature end of script headers: /home/www/cgi-bin/mapserv
> Any idea what I could do to get mapserver running?
> BTW: during compilation I had to set the LibJPEG
> directory though the libary is at a standard location
> Thanks for any help
> Franziska
