[mapserver-users] Point inside or outside polygon???
Steve Lime
steve.lime at dnr.state.mn.us
Thu Aug 1 15:06:26 EDT 2002
And MapServer can do this to. Just use mode=nquery and give your polygon
layer a non-zero tolerance. The point query capability was originally
built for web apps where a user clicks on a feature (imagine that) and
this is really a non-issue. If you think about how hard it is to
actually come up with a point exactly on a line segment for most
purposes the current setup it fine, but not foolproof but as mentioned
about there are workarounds. For a discussion of the current algorithm
and alternatives check out subject 2.03 in the comp.graphics.algorithms
FAQ at www.faqs.org.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Norman Vine" <nhv at cape.com> 08/01/02 10:29AM >>>
Jan Hartmann writes:
>Yes, I understand that it can be impossible to identify a
>unique polygon for
>a point query, both in practice and theory. In that case,
>however, I would
>prefer to have both polygons returned to me, instead of just
>one chosen at
>random. At least I know that something IS indeterminate then.
Jan
I think that this is one of those attributes of a GIS that Mapserver
doesn't necessarily try to do for 'performance' reasons, also there
may be more then 2 poylgons sharing a point further complicating
the solution.
AFAIK many GIS applications will not give a determinate answer
for a simple point in poly request either, however they will return
a list of polygons intersected by another polygon.
i.e. a point with area
FYI
I believe that there is work underway to include 'polygon algebra'
functionality in PostGIS which will allow you todo this kind of query
see
http://www.vividsolutions.con/jts/jtshome.htm
Cheers
Norman
