[mapserver-users] libpdf.so.1: cannot open shared object file
    Lowell.Filak
    lfilak at medinaco.org
    Tue Aug  6 05:14:01 PDT 2002
Is /usr/local/lib in /etc/ld.so.conf, and if so does 'ldconfig -v | grep
libpdf.so.1' show libpdf.so.1 or does it show libpdf.so.1.0.0? I think
libpdf.so.1.0.0 can be mv'd to libpdf.so.1 (but that looks like an older
prob). If libpdf.so.1 is shown then just running ldconfig should fix the problem.
HTH
Lowell F.
On Mon, 5 Aug 2002, Albin Blaschka wrote:
> Hello out there!
> I compiled Mapserver 3.6, with following configure-options:
> --with-gd --with-proj --with-pdf
> 'configure' and 'make' brought *no* errors. The binary 'mapserv' *is*
> created. But when I want to test it with ./mapserv (like it is said in the
> documentation) I get the following error:
> 'error while loading shared libraries: libpdf.so.1: cannot open shared
> object file: No such file or directory'
> The files lay in /usr/local/lib/libpdf.a, libpdf.la, libpdf.so
> My box:
> Debian 3.0 Woody
> MapServer 3.6.1
> Is there help possible ?
> Albin
> //  Albin Blaschka, Mag. rer. nat.
> //  Etrichstraße 26
> //  A - 5020 Salzburg
> //  It´s hard to live in the mountains,
> //  hard, but not hopeless!
More information about the MapServer-users
