[mapserver-users] OGR - ArcInfo Coverage Help
Matthew Archer
ma at t-kartor.se
Fri Aug 9 06:38:25 EDT 2002
I am trying to draw ArcInfo annotation via OGR, using MapServer v3.6.1
(windows binary) on Windows NT.
I cannot get MapServer to draw the actual annotation text. Is this
possible, have i got a syntax error somewhere.
regards
/Matthew
Extract from arc DESCRIBE command on cover:
Description of DOUBLE precision coverage anno15b
FEATURE CLASSES
Number of Attribute Spatial
Feature Class Subclass Features data (bytes) Index?
ANNOTATIONS SDE 2188 524 Yes
Extract from arc ITEMS anno15b.tatsde command on cover:
ITEM NAME WIDTH OUTPUT TYPE
SDE# 4 5 B
SDE-ID 4 5 B
OBJECT_ID 4 10 B
ANNOTYPE 30 30 C
NAME 250 250 C
Using the following syntax with TYPE=Point:
LAYER
NAME anno15
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "C:\apache\htdocs\gt2\data\anno15b,0"
STATUS default
CLASS
COLOR 0 0 0
END
END
Mapserver draws points at the start of where each annotation string should be.
Using the following syntax with TYPE=Annotation:
LAYER
NAME anno15
TYPE ANNOTATION
CONNECTIONTYPE OGR
STATUS default
CLASS
COLOR 0 0 0
END
END
Mapserver draws nothing for this layer, but gives no error either. The
rest of the layers still draw.
Using the following syntax with TYPE=Annotation and with a TEXT fixed label:
LAYER
NAME anno15
TYPE ANNOTATION
CONNECTIONTYPE OGR
STATUS default
CLASS
COLOR 0 0 0
TEXT "hello"
LABEL
COLOR 0 0 0
END
END
END
Mapserver draws the default text where each annotation string should have been.
Using the following syntax with TYPE=Annotation and with a LABELITEM:
LAYER
NAME anno15
TYPE ANNOTATION
CONNECTIONTYPE OGR
STATUS default
LABELITEM "NAME"
CLASS
COLOR 0 0 0
END
END
MapServer gives the error:
msOGRLayerInitItemInfo(): OGR error. Invalid Field name: NAME
I have tried both NAME,name,Name without success
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020809/6ceceb08/attachment.html
