[mapserver-users] Mapplet Problem
Doug Braeckel
BraeckelD at etminc.com
Fri Aug 9 13:49:07 EDT 2002
Tom,
Yes, I've printed and read the HOW-TO, good stuff. I've tried every
combination of [host] [port] [img] I can imagine, and I don't get any errors
in the status bar. This thing's driving me nuts. You can check it out at:
http://www.duvalCountyNPDES.net/
Click the gold NPDES logo at the top to get to the map. I've included a
table of the variables at the bottom of the page.
The raw CGI version of this worked fine. I'd just like to use Javascript to
get this to function and look like our ArcIMS version.
Thanks for any help you can provide,
Doug
Doug Braeckel
Senior GIS Programmer
England, Thims & Miller, Inc.
PH: (904) 642-8990
FX: (904) 646-9485
-----Original Message-----
From: Kralidis, Tom [mailto:Tom.Kralidis at CCRS.NRCan.gc.ca]
Sent: Friday, August 09, 2002 12:34 PM
To: 'Doug Braeckel'; 'mapserver-users at lists.gis.umn.edu'
Subject: RE: [mapserver-users] Mapplet Problem
You need the hostname. The mapplet requires fully qualified URLs.
1./ Have you check the mapplet-howto on the UMN MapServer website?
2./ Have you tried: http://[host]/[img]
3./ Do you get any errors in the status bar?
..Tom
> From: Doug Braeckel [mailto:BraeckelD at etminc.com]
> Sent: Friday, August 09, 2002 11:41 AM
> To: 'mapserver-users at lists.gis.umn.edu'
> Subject: [mapserver-users] Mapplet Problem
> I've been using the base MapServer for the last few months with good
> results. I'm currently using Windows 2000, IIS, MapServer
> 3.6.1. I also
> have a duplicate running on Windows 2000 Workstation with
> Apache 1.3.24.
> I am now trying to add Mapplet to my application with poor results.
> Everything Javascript appears to be working (clicks and drags
> work) except
> that I cannot, no matter what I try, get the map image [img]
> to display in
> the applet (on either computer). All I get is a white square
> where the map
> would display. I've tried every combination of
> "http://[host][port][img]"
> I've seen. I'm now down to just [img] which contains the
> full path the
> image. In fact, when I VIEW PAGE SOURCE and copy the [img] link into
> Netscape, I can view the map image by itself, so I know the
> reference to the
> image is good.
> Has anyone else had a similar problem with getting MAPPLET
> working? What am
> I doing wrong? I thought this would be easier than ROSA,
> which I also can't
> get to work correctly.
> Sincerely,
> Doug Braeckel
> PH: (904) 642-8990
> FX: (904) 646-9485
