[mapserver-users] build 3.6.1 warnings and errors
Alex Rice
alex_rice at arc.to
Fri Aug 9 15:53:00 EDT 2002
On Friday, August 9, 2002, at 08:54 AM, Puneet Kishor wrote:
> Build help needed. Many tia.
> Trying to install ms3.6.1 on OS X 10.1.5 with gcc 3 (I think).
> Stock build, using nothing fancy but gd, png, etc. MapServer
> builds except for the warnings and confusing msg below.
No clue about the others
> /usr/bin/ld: table of contents for archive:
> /usr/local/lib/libmap.a is out of date; rerun ranlib(1) (can't
> load from it)
For the above, all you need to do is this
# sudo ranlib /usr/local/lib/libmap.a
usually the installer script should do this, but maybe it doesn't
or is expecting a different command to do it (like on linux?)
Alex Rice, Software Developer
Architectural Research Consultants, Inc.
alex_rice at arc.to
alrice at swcp.com
