[mapserver-users] malformed PNGs
Puneet Kishor
pkishor at GeoAnalytics.com
Tue Aug 13 18:01:22 EDT 2002
Lowell,
Thanks for you guidance. Re my original problem... for some strange reason
now I can get PNGs made correctly. Obviously something has changed but I
have no idea what. To answer another post by Alex Rice, when I opened the
malformed PNGs in a text editor I saw a bunch of gobbledegook but no error
messages... I also saw some reference to gd-jpeg, but I don't remember the
exact words. Anyway, I am able to make PNGs fine now.
Wrt the log file, I still can't get the log file to be written out. Yes, the
directory has write permission for everybody, which includes user apache. As
I said, I have added the following at the top of my perl script
$ENV{MS_ERRORFILE} = "/var/www/html/bims/tmp/mapserver.log";
but, no success. Would be nice to keep this log,
Thanks,
pk/
> -----Original Message-----
> From: Lowell.Filak [mailto:lfilak at medinaco.org]
> Sent: Tuesday, August 13, 2002 11:59 AM
> To: Puneet Kishor
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: RE: [mapserver-users] malformed PNGs
> The LOG is for logging requests whereas the ERRORFILE is for logging
> errors. Does the user that the webserver is running as have
> permission to
> write to /var/www/html/bims/tmp/mapserver.log or alternately
> /var/www/html/bims/tmp/error.log? There should at least be a
> log file with
> a record of the request.
> Lowell
> On Tue, 13 Aug 2002, Puneet Kishor wrote:
> > well, I already had a line in my map file like so...
> > LOG "/var/www/html/bims/tmp/mapserver.log"
> > I added
> > to my perl script. I don't get any log files written out.
> Do I have to set
> > this ENV variable in the Apache conf file? or at the shell
> prompt using
> > setenv?
> > Tia,
> > pk/
> > > If you already have
> > > $ENV{MS_ERRORFILE} = "/var/log/mapserver.log"
> > > near the top of your perl script does the log show an error while
> > > rendering any of the layers?
> > > Lowell F.
> > > On Mon, 12 Aug 2002, Puneet Kishor wrote:
> > > > I am getting malformed PNGs... they are being made all
> > > right, but they are
> > > > only about 3 to 4 k in length. The browser is unable to
> > > show them, and of
> > > > course, opening them with an image application gives an
> > > error... "Not a
> > > > valid PNG file".
> > > > Any idea why?
> > > > I am using ms3.5 with Perl/Mapscript.
> > > > the machine I am developing on, a beatup box with RH 7.2,
> > > works just fine
> > > > for a PHP Mapscript application.
> > > > pk/
