[mapserver-users] PHP mapscript as Apache module: clarification?
Vinko Vrsalovic
vinko at cprsig.cl
Wed Aug 14 19:43:20 EDT 2002
On Wed, Aug 14, 2002 at 09:29:37AM -0600, Alex Rice wrote:
> I have seen some confusing posts on the list about this issue.
> After re-reading the PHP mapscript installation docs, I think
> that it's OK to use PHP mapscript with PHP as an Apache DSO
> module, **except on Windows** in which case you should use CGI
> PHP only because of thread safety issues. Is this a correct
> assessment?
No. The 3.6 branch should be run as a CGI on all platforms, in fact, if
you try to load the mapscript extension from a DSO module, you only get
a 'this must run as a CGI' error page.
Vinko Vrsalovic <vinko[|- at -|]cprsig.cl>
http://www.cprsig.cl
