[mapserver-users] mapserver.log (was Re: malformed PNGs)
Puneet Kishor
pkishor at GeoAnalytics.com
Wed Aug 14 21:18:40 EDT 2002
Thanks Lowell, Steve, and Steve.
That is now clear. Which brings me to a few random issues --
1. if Lowell hadn't told me about $ENV{MS_ERRORFILE}, how could I have
found that out? I think I have peered into all the Perl/Mapscript docs
there are but didn't see this. Maybe I missed it, but maybe it isn't
there, or is not obvious. In which case, we (I myself) need to do
Perl/Mapscript a service and really make a nice Perl how-to. I frankly
love Perl over all other scripting stuff, but find PHP stuff to be
generally better documented. For example, it was not obvious trying to
figure out the changes from 3.5->3.6.1. The mapquakes.pl script is
great, but it is hardly adequate. I have finally got my Perl/Mapscript
application behaving and will be releasing it a la gMap (I am planning
to call it pMap for the heck of it! so don't be taking away the name
from me!!), but we really need more.
2. SDL says (and so did SW) --
> The error in your log files is completely benign and can be safely
> ignored. It just says that
> there is no spatial index associated with a particular shapefile, which
> is perfectly legal...
well, then why doesn't the error say just that? I mean, instead of
Tue Aug 13 23:10:51 2002 - msSearchDiskTree(): Unable to access file.
it could just as well have been
Tue Aug 13 23:10:51 2002 - msSearchDiskTree(): no spatial index
associated with hydro.shp
associated with roads.shp
is there a good reason why error messages have to be cryptic? That is
one great turn-off I had with ESRI software -- I mean, anytime any of
their products version 1.x onward croaked, it said there was a "Fatal
error, segmentation fault". I couldn't even pick my nose with that info!
3. I am getting a boatload of errors in my Apache error_log like so
[Wed Aug 14 08:44:07 2002] index.pl: (in cleanup) Not a HASH
reference at /Library/Perl/darwin/mapscript.pm line 2415 during global
destruction.
reference at /Library/Perl/darwin/mapscript.pm line 1144 during global
destruction.
[Wed Aug 14 08:44:07 2002] index.pl: Use of uninitialized value in
exists at /Library/Perl/darwin/mapscript.pm line 2417 during global
destruction.
Things seem to be working, so are the above also benign, so to say? I am
not using mod_perl any more... this with Perl 5.6.1 with Apache 1.3.26
on OS X. However, I have had the same error on Win2k, Perl 5.6.1, Apache
2.0.39.
4. What is the compatibility of Perl/Mapscript with Perl 5.8.0? If it is
not, I won't even worry about upgrading Perl, but would like to know.
5. Not too long ago we narrowed a bunch of errors to mod_perl use
(methinks they were like those mentioned above in #3) that actually
crashed the program, in that, the map didn't draw (the dreaded "Internal
Server Error has occurred..."). What is the future possibility of
Perl/Mapscript co-existing with mod_perl?
I know these are many questions, and I don't mean to sound over-eager.
My main interest is in better (best possible) debugging, so answers to
#2 and #3 would be very satisfying. As the great Lowell.Filak wrote on
Wednesday, August 14, 2002, at 06:17 AM,: "Error messages are a
terrible thing not to have."
pk/
> Steve
>>>> Puneet Kishor <pkishor at GeoAnalytics.com> 08/13/02 11:23PM >>>
> slowly slowly we progress...
> I am finally able to get mapserver.log to generate. I added the $ENV
> line immediately after the shebang line, and chown-ed the tmp directory
> to nobody. Works!
> ok. so I am now watching the log file with
> tail -f ...
> and I see the following...
> Tue Aug 13 23:11:46 2002 - msSearchDiskTree(): Unable to access file.
> the problem is, I can't figure out what is causing the above error. My
> map file is fairly complicated, and as far as I can see, everything is
> being drawn the way I want it. So, what is it that is inaccessible? Is
> there a way the log can append (or prefix) the line number in the source
> that caused the error? Is there a way to determine where it is failing?
> Tia as always.
> pk/
> On Tuesday, August 13, 2002, at 11:58 AM, Lowell.Filak wrote:
>> The LOG is for logging requests whereas the ERRORFILE is for logging
>> errors. Does the user that the webserver is running as have permission
>> to
>> write to /var/www/html/bims/tmp/mapserver.log or alternately
>> /var/www/html/bims/tmp/error.log? There should at least be a log file
>> with
>> a record of the request.
>> Lowell
>> On Tue, 13 Aug 2002, Puneet Kishor wrote:
>>> well, I already had a line in my map file like so...
>>> LOG "/var/www/html/bims/tmp/mapserver.log"
>>> I added
>>> $ENV{MS_ERRORFILE} = "/var/www/html/bims/tmp/mapserver.log"
>>> to my perl script. I don't get any log files written out. Do I have to
>> set
>>> this ENV variable in the Apache conf file? or at the shell prompt
>> using
>>> setenv?
>>> Tia,
>>> pk/
