[mapserver-users] Multiple projection problem
Matthew Hatcher
MJHatcher at space.qinetiq.com
Thu Aug 15 05:39:56 EDT 2002
Hi people,
I'm having problems with using different projections in MapServer. If I try
and merge data in different projections, the datasets requiring reprojecting
don't get displayed.
I am using the NT MapServer 3.6.1 binary compiled with GDAL and PROJ4
support. My WMS default projection is lat/long, but I have datasets in UK
National Grid (epsg:27700) which it should be possible to reproject.
I'm having this problem with both rasters and vectors, but I've only
included my vector map file below.
Help would be appreciated!!
Matt Hatcher.
--- map file ---
# Start of map file
NAME MAIN
STATUS ON
SIZE 600 350
EXTENT -140570 -33340 956950 606250 # osgb
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 192 192 192
# you may need to change this to match your MapServer build
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
PROJECTION
"init=epsg:4326"
END
# Start of web interface definition (including WMS enabling metadata)
WEB
TEMPLATE test.html
MINSCALE 1000
MAXSCALE 7000000
IMAGEPATH "w:\wwwroot\tmp\"
IMAGEURL "/tmp/"
METADATA
WMS_TITLE "foo"
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "foo"
WMS_SRS "EPSG:27700 EPSG:4326" # OSGB and lat/long
END
END
# Start of layer definitions
LAYER
NAME "uk_osgb"
TYPE LINE
STATUS DEFAULT
DATA uk_osgb
GROUP uk_osgb
CLASS
COLOR 0 0 128
END
METADATA
WMS_TITLE "UK outline"
WMS_ABSTRACT "Boundary of UK region"
WMS_GROUP_TITLE "UK boundaries"
END
PROJECTION
"init=epsg:27700"
END
END
END # Map File
The information contained in this email and any subsequent
correspondence is private and is intended solely for the
intended recipient(s). For those other than the intended
recipient(s) any disclosure, copying, distribution, or any
action taken or omitted to be taken in reliance on such
information is prohibited and may be unlawful.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020815/afb0261e/attachment.html
