[mapserver-users] Problem with specifying data parameter for postgis layer
N A
booklong at hotmail.com
Sat Aug 17 19:18:00 EDT 2002
Dear all,
Could someone please let me know if sub queries are allowed in specifying
the data parameter for a postgis layer.
when I specify the data parameter as:
LAYER
DATA "the_geom from places"
END
it works
on the otherhand, I would like to be able to manipulate the query a bit more
so I try to use:
LAYER
DATA "the_geom from (select the_geom,featuretype,featurename from places) as
foo"
END
this fails.
I went back and browsed thru the mappostgis.c source code and I found the
following:
Must contain 'geometry_column from table_name' or 'geom from (subselect) as
foo'
Any help will be appreciated.
Thanks
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
