[mapserver-users] rosa, projection and query problem
Debbie Pagurek
pagurekd at agr.gc.ca
Tue Aug 20 10:19:39 EDT 2002
OK - I solved my problem. For some reason, after I added the projection tags the application no longer "liked" TOLERANCE 0. So I added TOLERANCEUNITS METERS to my map file, and changed the TOLERANCE to 1 and the query part of the application works again.
So the question is... why doesn't TOLERANCE 0 work once the projection information is added? I wasn't actually changing the projection of the layers, I just added the projection tags so that the app can be used as a WMS server.
D. Pagurek
>>> "Debbie Pagurek" <pagurekd at agr.gc.ca> 08/19/02 03:29PM >>>
Hi everone,
I've developed an application using Mapserver CGI, the ROSA applet, and shapefiles that are in decimal degrees. The application works, including the queries on the polygons, as long as I don't include any projection information in the map file. However, I am trying to set this application up for use as a WMS server, and as soon as I put the projection tags into the mapfile e.g.
PROJECTION
"init=epsg:4267"
END
(this tag is in each layer definition as well as at the very top section of the mapfile)
everything works EXCEPT for the query, which results in the following:
msQueryByPoint(): Search returned no results. No matching record(s) found
But as far as I can tell from the URL, nothing has changed as a result of the click on the map.
Is there some sort of underlying conflict with PROJ and ROSA (i doubt that)... can anyone shed any light on this frustrating problem I'm having?
see below for the mapfile
I have another application that is set up the same way for use as a WMS server but it doesn't use ROSA... and it works fine, so I don't think this is a problem with the PROJ setup.
D. Pagurek
# Start of map file
NAME ECOROSA
STATUS ON
SIZE 500 250
EXTENT -150 40 -50 90
UNITS dd
SHAPEPATH "c:\inetpub\wwwroot\ms_demo\eco\data"
IMAGECOLOR 255 255 255
# Projection definition, consult the PROJ.4 documentation for parameter discussion
PROJECTION
"init=epsg:4267"
END
# Start of web interface definition
WEB
IMAGEPATH "C:\Inetpub\wwwroot\temp\"
IMAGEURL "/temp/"
TEMPLATE eco_rosa.html
METADATA
"wms_title" "WMS Ecostratification"
"wms_onlineresource" "http://myhost/scripts/mapserv.exe?"
"wms_srs" "EPSG:4267"
...etc...
END #metadata
END #WEB
QUERYMAP
SIZE 500 250
STATUS ON
STYLE HILITE
COLOR 255 255 0
END
# Start of reference map
REFERENCE
IMAGE "c:\inetpub\wwwroot\ms_demo\aveco2\ref_map.gif"
SIZE 100 50
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
STATUS ON
OUTLINECOLOR 0 0 0
#KEYSIZE 18 12
KEYSIZE 16 10
LABEL
TYPE BITMAP
SIZE SMALL
COLOR 0 0 0
END
END #LEGEND
# Start of scalebar
SCALEBAR
STATUS ON
LABEL
COLOR 255 0 0
SIZE tiny
END #LABEL
STYLE 1
SIZE 200 2
COLOR 153 153 153
UNITS kilometers
INTERVALS 3
END #SCALEBAR
# Start of layer definitions
LAYER
NAME 'Ecozones'
TYPE Polygon
STATUS ON
DATA ecozones
TEMPLATE "ecoquery1.html"
FOOTER "ecofooter.html"
CLASSITEM 'ZONE'
CLASS
EXPRESSION '1'
NAME 'Arctic Cordillera'
COLOR 204 255 255
END # CLASS
CLASS
EXPRESSION '2'
NAME 'Northern Arctic'
COLOR 153 204 204
END # CLASS
CLASS
EXPRESSION '3'
NAME 'Southern Arctic'
COLOR 0 153 204
END # CLASS
CLASS
EXPRESSION '4'
NAME 'Taiga Plains'
COLOR 204 204 204
END # CLASS
CLASS
EXPRESSION '5'
NAME 'Taiga Shield'
COLOR 153 153 153
END # CLASS
CLASS
EXPRESSION '6'
NAME 'Boreal Shield'
COLOR 102 204 102
END # CLASS
CLASS
EXPRESSION '7'
NAME 'Atlantic Maritime'
COLOR 102 204 204
END # CLASS
CLASS
EXPRESSION '8'
NAME 'Mixed Wood Plains'
COLOR 255 204 153
END # CLASS
CLASS
EXPRESSION '9'
NAME 'Boreal Plains'
COLOR 204 255 204
END # CLASS
CLASS
EXPRESSION '10'
NAME 'Prairies'
COLOR 255 255 153
END # CLASS
CLASS
EXPRESSION '11'
NAME 'Taiga Cordillera'
COLOR 204 153 204
END # CLASS
CLASS
EXPRESSION '12'
NAME 'Boreal Cordillera'
COLOR 153 102 204
END # CLASS
CLASS
EXPRESSION '13'
NAME 'Pacific Maritime'
COLOR 0 102 0
END # CLASS
CLASS
EXPRESSION '14'
NAME 'Montane Cordillera'
COLOR 153 204 000
END # CLASS
CLASS
EXPRESSION '15'
NAME 'Hudson Plains'
COLOR 204 255 153
END # CLASS
TOLERANCE 0
PROJECTION
"init=epsg:4267"
END
METADATA
"wms_title" "Ecozones"
"wms_Srs" "EPSG:4267"
"wms_abstract" "An area at the earth's surface representative of large and very generalized ecological units characterized by various abiotic and biotic factors. "
"wms_extent" "-150 40 -50 90"
"wms_opaque" "1"
END
END # LAYER
LAYER
NAME Ecodistricts
TYPE Polygon
STATUS ON
DATA eco
TEMPLATE "ecoquery3.html"
CLASS
NAME "Ecodistricts"
OUTLINECOLOR 204 0 0
END # CLASS
TOLERANCE 0
PROJECTION
"init=epsg:4267"
END
METADATA
"wms_title" "Ecodistricts"
"wms_abstract" "A part of an ecoregion characterized by distinctive assemblages of relief, geology, landforms,soils, vegetation, water, and fauna."
"wms_opaque" "0"
END
END # LAYER
LAYER
NAME Ecoregions
TYPE Polygon
STATUS ON
DATA ecoregions
HEADER "ecoheader.html"
TEMPLATE "ecoquery2.html"
CLASS
NAME 'Ecoregions'
OUTLINECOLOR 0 0 0
END #CLASS
TOLERANCE 0
PROJECTION
"init=epsg:4267"
END
METADATA
"wms_title" "ecoregions"
"wms_abstract" "A part of an ecozone characterized by distinctive regional ecological factors, including climate, physiography, vegetation, soil, water and fauna."
"wms_opaque" "0"
END
END #LAYER
END # MAPFILE
