[mapserver-users] Which WMS Versions are supported?
Daniel Morissette
morissette at dmsolutions.ca
Tue Aug 20 15:48:59 EDT 2002
I thought that I had noticed a similar behavior before but had not found
time to investigate yet. This is not exactly the expected behavior, so
yes please file as a bug and I'll try to look into this for the 3.7
release.
Daniel
"Smith, Michael ERDC-CRREL-NH" wrote:
> Thanks Dan, that solved the problem (--enable-debug, works great). It turns out that the problem was multiple srs's in the wms metadata. I put in all the epsg codes that the server supports in the wms metadata and the epsg that I wanted in the projection part but it was always sending the URL with the first epsg code from the wms-metadata. Is that how its supposed to work or should I file this in bugzilla?
> Mike Smith
> email: michael.smith at erdc.usace.army.mil
> RSGISC
> ERDC - CRREL
> Hanover, NH 03755
> (603) 646-4765
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Tuesday, August 20, 2002 11:22 AM
> To: Smith, Michael ERDC-CRREL-NH
> Cc: 'mapserver-users at lists.gis.umn.edu'
> Subject: Re: [mapserver-users] Which WMS Versions are supported?
> MapServer 3.6 supports only up to 1.1.0 in server mode, but I see no
> reason why it wouldn't work with a 1.1.1 server as a client since there
> were no major changes in the GetMap requests between 1.1.0 and 1.1.1.
> If you're running on Unix, can you please compile your MapServer using
> the --enable-debug configure option, and then look at the web server's
> error_log and you'll see the URL that is used for the GetMap request...
> with that URL it should be possible to figure what's happening. You may
> also see some useful error messages in the error_log.
> Note that there is no debugging information output to the error_log on
> Windows, so this will work only on Unix servers.
> Finally, once you have the faulty URL, could you please file a bug about
> this in bugzilla so that we have a trace of the problem and it doesn't
> fall in a crack?
> Thanks
> Daniel
> > Is wms version 1.1.1 not supported? I've been connecting to a wms version 1.1.0 server and its been working fine. Now I've tried to get to a 1.1.1 server (Microsoft TerraServer) and I get no image.
> > Here's the layer specs I've been using
> > LAYER
> > NAME terraserver
> > METADATA
> > "wms_title" "Raster/USGS DRG"
> > "wms_srs" "EPSG:26905 EPSG:26906 EPSG:26910 EPSG:26911 EPSG:26912 EPSG:26913 EPSG:26914 EPSG:26915 EPSG:26916 EPSG:26917 EPSG:26918 EPSG:26919 EPSG:26920"
> > END
> > TYPE RASTER
> > STATUS default
> > CONNECTIONTYPE WMS
> > CONNECTION "http://terraservice.net/ogcmap.ashx?version=1.1.1&service=wms&LAYERS=DRG&FORMAT=image/jpeg&styles="
> > PROJECTION
> > "init=epsg:26911"
> > END
> > END
> > When I connect using a direct URL and fill in the bbox, etc, I get an image.
> > i.e. <http://terraservice.net/ogcmap.ashx?version=1.1.1&request=getmap&service=wms&LAYERS=DRG&FORMAT=image/jpeg&bbox=564953.8894514536,3694151.203736646,608893.7801618363,3734423.32393698&width=600&height=550&srs=epsg:26911&styles=>
> > Anyone know why?
> > Mike Smith
> > RSGISC
> > ERDC - CRREL
> > Hanover, NH 03755
> > (603) 646-4765
