[mapserver-users] bug with mapscript and MS_ERRORFILE?
Alex Rice
alex_rice at arc.to
Tue Aug 20 22:18:18 EDT 2002
I have been absolutely nuts for a little bit here... I think I
may have found a really bizarre mapscript bug. Using Perl
mapscript 3.6.1, unmodified, the following test script goes into
an infinite loop and fills mapserver.log with
"msAddImageSymbol(): Unable to access file.".
If I do any of the following 3 things, the script executes fine
and no infinite loop occurs.
1) comment out the line $ENV{MS_ERRORFILE} = "...";
2) remove the mapserver.log file.
3) remove write permissions on the mapserver.log file.
-- test script --
#!/usr/bin/perl
$ENV{MS_ERRORFILE} = "/var/log/mapserver.log";
use mapscript;
my $mapObj = new mapObj('aps.map') or die("Unable to open mapfile");
my $filename = $mapObj->{web}->{imagepath} . $$. '.png';
my $imgObj = $mapObj->draw; # <------------------------- goes
into infinite loop here
$res = $imgObj->saveImage($filename,
$mapscript::MS_PNG, # image type
$mapscript::MS_TRUE, # transparency
$mapscript::MS_TRUE, # interlace
-1); # quality % (applicable to jpg only)
die "saveImage() returned '$res'";
--end test script--
Alex Rice, Software Developer
Architectural Research Consultants, Inc.
alex_rice at arc.to
alrice at swcp.com
