RES: [mapserver-users] Anybody have updated Mapserver Utilities??
woodbri at swoodbridge.com
Thu Aug 22 15:10:44 EDT 2002
While this is an excellent utility there is a much simpler way to get
the extents of the shape file. See the below, and the file extents
are list as File Bounds (xmin, ymin) to (xmax, ymax).
[woodbri at linus mdata]$ shpdump nhpnnd | head
Shapefile Type: Point # of Shapes: 125797
File Bounds: ( -176.766473, 17.932413,0,0)
to ( 179.391600, 71.316577,0,0)
Shape:0 (Point) nVertices=1, nParts=0
Bounds:( -156.744416, 71.316577, 0, 0)
to ( -156.744416, 71.316577, 0, 0)
Broken pipe
On 22 Aug 2002 at 14:50, EDUARDO PATTO KANEGAE wrote:
> I don´t think this is "really" a good utiliti, but here it goes:
> i´ve just worked in a project that was an intranet n it has a report that
> must show a grid, containting atributes, and too a map of the
> grid(or a map of the forest specifcaly)...
> and the problem in this application is that each map should appear in its
> full extent. so, i dit this:
> 1.execute the utility SHPDUMP, with something like:
> $ shpdump mymap.shp > mymap.dmp // dmp -> Dump file result
> 2.execute the my PHP funtion 'get_shp_corners' passing the dumpfile as
> parameter:
> $result = get_shp_corners('mymap.dmp');
> 3.and EURECA! finally got 2 coordinates at $result array that can be used to
> set the EXTENT parameter of my MapFiles. e.g. :
> i can write a MapFile using:
> EXTENT x1 y1 x2 y2
> where:
> x1 = $result[0]
> y1 = $result[1]
> x2 = $result[2]
> y2 = $result[3]
> 4.so, let´s see the PHP code:
> get_shp_corners: returns an array containing x1 y1 x2 y2 - that is the full
> extent - of a ShapeFile, based on its dumpfile
> $dumpfile = a text file that is generated with the shpdump command
> Author: Eduardo Patto Kanegae <eduardo at scopotecnologia.com.br>
> function get_shp_corners($dump_filename){
> $dmp_hwnd = fopen($dump_filename,'r');
> if (!$dmp_hwnd){
> return FALSE;
> } else {
> fclose($dmp_hwnd);
> $vet_lin_dumpfile = file($dump_filename);
> $p_found[0]=FALSE;
> $p_found[1]=FALSE;
> $p_found[2]=FALSE;
> $p_found[3]=FALSE;
> $tmp[0] = "";
> $tmp[1] = "";
> $tmp[2] = "";
> $tmp[3] = "";
> for($j=0;$j<strlen($vet_lin_dumpfile[2]);$j++){
> $car = substr($vet_lin_dumpfile[2],$j,1);
> if ($car =="(" || ($p_found[0])){
> $p_found[0]=TRUE;
> if ($car!=","){
> if ($car !="(" && $car!=" "){
> $tmp[0] = $tmp[0] . $car;
> } else {
> $p_found[0]=FALSE;
> } elseif (($car=="0" || $car=="1" || $car=="2" ||
> $car=="3" || $car=="4" || $car=="5" || $car=="6" || $car=="7" || $car=="8"
> || $car=="9" || $car=="-" || $car==".") || ($p_found[1])){
> $p_found[1]=TRUE;
> if ($car!=","){
> $tmp[1] = $tmp[1] . $car;
> } else {
> break;
> $p_found[1]=FALSE;
> for($j=0;$j<strlen($vet_lin_dumpfile[3]);$j++){
> $car = substr($vet_lin_dumpfile[3],$j,1);
> if ($car =="(" || ($p_found[2])){
> $p_found[2]=TRUE;
> if ($car!=","){
> $tmp[2] = $tmp[2] . $car;
> } else {
> $p_found[2]=FALSE;
> || $car=="9" || $car=="-" || $car==".") || ($p_found[3])){
> $p_found[3]=TRUE;
> if ($car!=","){
> $tmp[3] = $tmp[3] . $car;
> } else {
> break;
> $p_found[3]=FALSE;
> return $tmp;
> regards
> eduardopk at vcp.com.br <mailto:eduardopk at vcp.com.br>
> Time Planejamento - UNIDADE LA - Ramal 9126
> eduardo at scopotecnologia.com.br <mailto:eduardo at scopotecnologia.com.br>
> http://www.scopotecnologia.com.br
> -----Mensagem original-----
> De: Dean Gadoury [mailto:gadoury at dmsolutions.ca]
> Enviada em: quinta-feira, 22 de agosto de 2002 11:32
> Para: Mike Smith; mapserver-users at lists.gis.umn.edu
> Assunto: RE: [mapserver-users] Anybody have updated Mapserver
> Utilities??
> Mike, have you tried MapLab? You can get information about it and download
> it at the following address:
> http://www.dmsolutions.on.ca/maplab.html
> -----Original Message-----
> From: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu]On Behalf Of Mike Smith
> Sent: Thursday, August 22, 2002 10:26 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] Anybody have updated Mapserver Utilities??
> Hello,
> I have been beating my head against the wall trying to find
> utilities that will ease the development of Mapserver web pages to no
> avail! I have downloaded and tried all the utilities on the Mapserver
> home page but they don't work with my version of Mapserver! I'm running
> the latest stable version, 3.6.1, on a Sun box running Solaris 8. I've
> got mapserver working fine and the demo worked fine and mapplet works
> fine in my demo, the only thing is that the "Mapserver Workbench"
> developer told me that he has not updated his tool since Mapserver
> 3.4.x, so I can't use that, and "MapUtils" appears to be for old
> versions of Arcview and old versions of Mapserver as well! The files it
> generates don't work with my version of Mapserver. Has anybody updated
> Maputils, or any other tool for that matter, to work with Mapserver
> 3.6.1? I'd like to have something that generates the ".map" files out
> of ArcView at the very minimum, but I'll take whatever I can get in lieu
> of writing those config files manually!
> HELP?!?!?!
