[mapserver-users] php_mapscript.so and proj
Daniel Morissette
morissette at dmsolutions.ca
Mon Aug 26 11:38:44 EDT 2002
You probably did a 'make install' in the MapServer directory in the
past, and an old libmap.a from a previous build is still in your
/usr/local/lib directory. See:
http://mapserver.gis.umn.edu/wilma/mapserver-users/0208/msg00171.html
Daniel
Stefano Bonnin wrote:
> hi,
> i have installed mapserver 3.5 with proj4.4.5 support and when i try the
> command
> mapserv -v
> i get the output:
> MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
> INPUT=GDAL INPUT=SHAPEFILE
> ok ....
> after I have copied the php_mapscript.so in the php/extension directory and
> the phpinfo() output is the following:
> MapScript Version (Nov 27, 2001)
> MapServer version 3.5 (beta) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
> INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE
> why the module doesn't have the proj support? and why the mapserv cgi is a
> 3.5 version and the .so is a 3.5 beta version?
> thanks
> Outgoing mail is certified Virus Free. (FLASHH!)
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.381 / Virus Database: 214 - Release Date: 02/08/02
