[mapserver-users] building mapserver on W2000 with msvc++
Michael Schulz
mschulz at webgis.de
Tue Aug 27 11:16:08 EDT 2002
Ok, finally i solved it. The problem was related to the vc-project the
ft-212-package was providing ( i couldn't find a normal makefile ...).
The standard configuration links against a multi-threaded c runtime dll. I changed
that to single-threaded (in projects menu - settings - c/c++ - code generation -
Use run-time lib) and it finally worked. Great!
Thanks and cheers, Michael
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
