[mapserver-users] help with converting tiff to a shp file
Gerald Buckmaster
webmaster at buckoptimized.com
Wed Aug 28 00:58:43 EDT 2002
Greetings,
It sounds like a job for the GeoTIFF Specification. You can use geotifcp
with the -g argument to install metadata, then use listgeo -tfw to write the
worldfile.
GeoTIFF Metadata is nothing more than a text file that looks something like
this:
Geotiff_Information:
Version: 1
Key_Revision: 1.0
Tagged_Information:
ModelTiepointTag (2,3):
0 0 0
-110.410032 33.2834107 0
ModelPixelScaleTag (1,3):
0.000364376663 0.000323906075 0
End_Of_Tags.
Keyed_Information:
GTModelTypeGeoKey (Short,1): ModelTypeGeographic
GTRasterTypeGeoKey (Short,1): RasterPixelIsPoint
GTCitationGeoKey (Ascii,11): "CLARKE1866"
GeogCitationGeoKey (Ascii,11): "GEOGRAPHIC"
End_Of_Keys.
End_Of_Geotiff.
I believe you would most likely set the ModelTiepointTag to (8,3)
to handle your pixel/geocoord/elevation triplets. I've never seen
anyone use anything but 0 for the vertical. The example given
in the link below negates the use of ModelPixelScaleTag, which
basically means clients (software) are not allowed to infer that there
is a simple linear relationship between the raster data and the
geographic model coordinate space. That might be a problem
with some software...someone would need to try out with Mapserver
other than me, as I am officially on vacation when this email transmits.
More details about this can be read at:
http://www.remotesensing.org/geotiff/spec/geotiff3.html#3.2.1.
I highly recommend the entire Specification for late-night reading ;^)
Respectfully,
Gerald Buckmaster
www.imagery-analyst.com
----- Original Message -----
To: "Grant Marblestone" <GrantM at ATSER.com>;
<mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, August 27, 2002 16:24
Subject: Re: [mapserver-users] help with converting tiff to a shp file
> Or another way to think about the problems is:
> How could you come up with a world file for the tiff, if you know the
> lat/long of the end points of the four runways. So if you know the
> lat/long of eight pixels in the TIFF what would you have to do to
> make a world file?
> Anybody have a clue?
> -Steve
> On 27 Aug 2002 at 16:55, Grant Marblestone wrote:
> > I have a tiff (top image) of an airport, and thanks to steven
> > woodbridge, i also have a shp file with the runways of this airport.
> > I wish to convert the tiff to shp using perhaps the shp file i have
> > of the runways to line it up. Anyone here have any experience with
> > this and an easy way to do this? I know it wont be exact but i am
> > hoping to get as close as possible this way.
> > Thanks for any input you can provide,
> > Grant
