[mapserver-users] problems with itemfeaturenquery
Oliver Wesp
wesp at gdv.com
Wed Aug 28 04:35:22 EDT 2002
Hello everybody,
once again I'm trying to do some stuff with SDE-Layers. This time I like
to select features from one layer using a item query on another layer.
itemfeaturenquery should to the trick if I'm not totally wrong. What I
got is the following:
My Request:
http://myServer/cgi-bin/mapserv?map=/var/apache/htdocs/myDir/demo.map&mo
de=itemfeaturenquery&slayer=REGIONS&map_REGIONS_filter="NLG='kal'"&qLaye
r=myLayer&map_REGIONS_header=makeSelHeader.html&map_REGIONS_template=mak
eSel.html&map_REGIONS_footer=makeSelFooter.html
And here is the Result:
msSDELayerGetShape(): General error message. No items requested, SDE
requires at least one item.
Am I missing something here? Any help is appreciated.
kind regards
Oliver Wesp
Gesellschaft für geografische Datenverarbeitung
Binger Str. 49-51
D-55218 Ingelheim
Fon: +49 6132 714818
Fax: +49 6132 714828
E-Mail: wesp at gdv.com
