[mapserver-users] Scroll Restriction
Richard Greenwood
Rich at GreenwoodMap.com
Thu Aug 29 17:27:21 EDT 2002
I have pasted a javascript function in below that is a fairly brute force
approach to the problem. Using javascript is probably the only solution if
you are using CGI MapServer.
Rich
function pan(direction) {
var imgx, imgy, newx, newy; // current and new image
center in pixels
var nc, sc, ec, wc, nl, el, sl, wl; // north, south, east,
west, c = current, l = limit
imgx = [center_x]; imgy = [center_y]; // pixels
newx = imgx; newy = imgy; // defaults (may be reset
below)
nc = [maxy]; sc = [miny]; ec = [maxx]; wc = [minx]; //
Mapserver gives us current map extents
nl= 1850000; sl= 1320000; el= 2640000; wl= 2360000; // Teton
County bounding box
document.form1.zoomdir.value=0; // default (may be
reset below if zooming)
if (direction == 'zin') {
document.form1.zoomdir.value=1;
} else if(direction == 'zout') {
document.form1.zoomdir.value=-1;
} else if(direction == 'n') {
if (nc < nl)
newy=imgy-imgy;
} else if(direction == 'nw') {
if ((nc < nl) && (wc > wl)) {
newx=imgx-imgx;
newy=imgy-imgy;
} else if(direction == 'ne') {
if ((nc < nl) && (ec < el)) {
newx=imgx+imgx;
newy=imgy-imgy;
} else if(direction == 's') {
if (sc > sl) {
newy=imgy+imgy;
} else if(direction == 'sw') {
if ((sc > sl) && (wc > wl)) {
newx=imgx-imgx;
newy=imgy+imgy;
} else if(direction == 'se') {
if ((sc > sl) && (ec < el)) {
newx=imgx+imgx;
newy=imgy+imgy;
} else if(direction == 'e') {
if (ec < el)
newx=imgx+imgx;
} else if(direction == 'w') {
if (wc > wl)
newx=imgx-imgx;
document.form1.elements["img.x"].value=newx; // this creates a
pseudo click point
document.form1.elements["img.y"].value=newy;
document.form1.mode.value = "browse";
document.form1.target="_self";
document.form1.submit();
At 12:53 PM 8/28/2002 +0100, you wrote:
>Hi all,
>Is there a way to prevent user from 'scrolling' out of the provided dataset?
>e.g. If one is constantly recentering the map at points outside the
>image/shapefile.
>Regards,
>Stefan
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
