[mapserver-users] shape file extent
Vinko Vrsalovic
v at w.cl
Mon Feb 4 19:56:07 EST 2002
On Mon, Feb 04, 2002 at 01:14:50PM -0500, Shaik Anwar Hussain wrote:
> Hi List,
> Does any one know how to get the extent of a selected shape file.
ArcView: View->Properties->Area of Interest->Theme
AcrExplorer: Don't know how, but must be very similar to arcview.
PHP MapScript:
<?php
dl ('php_mapscript.so');
$shapef = ms_newShapefileObj("/your_dir/your_file_without_extension",
-1);
for ($i=0;$i<$shapef->numshapes;$i++) {
$extent = $shapef->getExtent($i);
echo "$i.- MINX $extent->minx ";
echo "MINY $extent->miny ";
echo "MAXX $extent->maxx ";
echo "MAXY $extent->maxy \n<br>\n";
$shapef->free();
(From that output you should select the lowest minx and miny and the
highest maxx and maxy for you to use as a global extent for that
shapefile, that should be easy to obtain from the script above)
You can translate this to perl if you like and run it from the console.
I seem to recall that in some of the examples of Perl mapscript (from
the source tree: mapserver/mapscript/perl/examples) there was a perl
script that did exactly that.
V. <v at w.cl>
