[mapserver-users] POSTGIS/Mapscript DB connection is not closing (FWD)
trussell at mtcsc.com
Mon Feb 4 19:46:11 EST 2002
Teb,
Postmaster is supposed to behave like that. It runs in the background and
fields requests. There's some great documentation on this at
http://www.postgresql.org/idocs/index.php?postmaster-start.html.
The code you included regards a topic I've been wondering about - doing a
postgis query from a point selection. Hope to get something working there...
Tom
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Cc: <jeffloun at refractions.net>
Sent: Monday, February 04, 2002 12:15 PM
Subject: [mapserver-users] POSTGIS/Mapscript DB connection is not closing
(FWD)
> ------------- Begin Forwarded Message -------------
> Date: Mon, 04 Feb 2002 12:19:20 -0800
> From: jeff lounsbury <jeffloun at refractions.net>
> X-Accept-Language: en
> MIME-Version: 1.0
> To: mapserver-info at lists.gis.umn.edu
> Subject: POSTGIS/Mapscript DB connection is not closing
> Content-Transfer-Encoding: 7bit
> After I use mapscript to query my postgis layer in my map, the
> postmaster that got run never dies/closes?
> Anyone have any idea on why this might be happening?
> Hhere is an exerpt of the offending mapscript code...
> file://turn the point where the user clicked on the image into a
lat/long
> co-ordinate
> $pt = ms_newPointObj();
> $lat = get_lat($map->extent->minx, $map->extent->maxx, $img_x,
> 700);
> $long = get_long($map->extent->miny, $map->extent->maxy, $img_y,
> 350);
> $pt->setXY($lat, $long);
> file://query the postgis layer
> $layer = $map->getLayer(5);
> $err = @$layer->queryByPoint($pt, MS_MULTIPLE, $missby);
> if($err == MS_FAILURE){
> echo "<font size=4 color=red>There were no results found, try
> zooming in closer.</font>";
> }else if( $err == MS_SUCCESS){
> $layer->open($img->shapepath);
> file://save the query results into an array
> $i=0;
> $result = $layer->getResult($i);
> while($result != FALSE && $i < 5){
> $shape = $layer->getShape($result->tileindex,
> $result->shapeindex);
> $value = $shape->values;
> $val[$i] = $value;
> $i++;
> $results_found =1;
> $layer->close;
> As well as the postgid layer in the mapfile:
> LAYER
> CONNECTIONTYPE postgis
> NAME "mypostgis"
> DATA "point from usage_points"
> CONNECTION "host=ox user=postgres port=5555 dbname=postgis_usage"
> STATUS DEFAULT
> TYPE POINT
> CLASS
> TEMPLATE query.html
> MINSIZE 10
> SYMBOL star
> COLOR 250 0 25
> END
> END
> ,thanks
> -Jeff
> ------------- End Forwarded Message -------------
