[mapserver-users] php/mapscript. error in getlayerbyname
Andrea Giacomelli
andreag at crs4.it
Tue Feb 5 11:46:23 EST 2002
I am porting (finally!) my old apps to 3.5, and I am gradually ironing
out some of the issues in the transition from 3.4
I have a .map file which is processed properly by php/mapscript (if I
just request a $map->draw() it is ok.
However I get a problem with getLayerByName: this is ok with some of the
layers, but returns an error with some of the others.
Warning: MapServer Error in : in c:\data\htdocs/mia/if/htdocs/t.php on
line 7
Fatal error: getLayerByName failed for : s1 in
c:\data\htdocs/mia/if/htdocs/t.php on line 7
Maybe I am missing something in the .map file translation ?
TIA and regards,
Andrea Giacomelli
# configurazione mappa per prototipo if webgis - dicembre 2001 - a. giacomelli
NAME DEMO
STATUS ON
SIZE 370 370
SYMBOLSET ../etc/symbols.sym
#EXTENT 1400000 4300000 1580000 4580000
EXTENT 1360000 4300000 1650000 4580000
UNITS METERS
SHAPEPATH "c:\users\andreag\if\data" # IFWEB ? la directory corrispondente a IF_DATA nella relazione
IMAGECOLOR 224 255 255
FONTSET ../etc/fonts.txt
#LABELOVERLAP FALSE
# Start of web interface definition
WEB
# On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
# of the drive where the .MAP file resides.
IMAGEPATH "c:\data\htdocs\tmp\"
IMAGEURL "c:\data\htdocs\tmp\"
LOG "gmap.log"
END
# Start of reference map
REFERENCE
IMAGE images/reference.gif
STATUS ON
COLOR -1 -1 -1
# COLOR 224 255 255
OUTLINECOLOR 255 0 0
SIZE 120 120
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
# IMAGECOLOR 255 0 0
# IMAGECOLOR -1 -1 -1
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 150 5
# COLOR 255 255 255
# COLOR -1 -1 -1
BACKGROUNDCOLOR 255 255 255
OUTLINECOLOR 0 0 255
UNITS kilometers
INTERVALS 5
#ifw STATUS EMBED
TRANSPARENT TRUE
STYLE 0
END
# Start of layer definitions
LAYER
NAME "la"
###v5 DESCRIPTION "Limammdec"
TYPE POLYGON
STATUS ON
DATA comuni
CLASS
NAME "Limamm class_name"
COLOR 200 245 220
OUTLINECOLOR 150 200 20
END
END # layer
LAYER
# SYMBOLSCALE 2000000
NAME "lo"
###v5 DESCRIPTION "Localita'"
TYPE POINT
STATUS ON
DATA loc
LABELITEM "Comune"
LABELMAXSCALE 500000
CLASS
# EXPRESSION "[LABIDX] < 100"
SYMBOL 7
SIZE 3
NAME "Localita'"
COLOR 0 0 0
LABEL
TYPE TRUETYPE
OFFSET 20 20
COLOR 0 0 200
BUFFER 4
FONT arial
MINSIZE 8
MAXSIZE 20
FORCE TRUE
END
END
TOLERANCEUNITS meters
TOLERANCE 1000
HEADER "Istat Comune"
###v5 QUERYITEM "Istat"
###v5 QUERY
###v5 EXPRESSION /./
###v5 TEMPLATE "Istat"
END
END # Layer
LAYER
SYMBOLSCALE 200000
NAME "s1"
###v5 DESCRIPTION "dati_1"
TYPE POINT
STATUS ON
DATA loc # Nota: come sopra per s0
CLASS
MINSIZE 2
MAXSIZE 30
SYMBOL 3
SIZE 10
NAME "s11"
COLOR 255 0 0
LABEL
FORCE TRUE
OFFSET 10 10
COLOR 0 10 0
TYPE TRUETYPE
FONT arial
MINSIZE 8
MAXSIZE 20
END
END
TOLERANCE 5
END # LAYER
LAYER
SYMBOLSCALE 200000
NAME "s0"
###v5 DESCRIPTION "dati_centrali"
TYPE POINT
STATUS ON
DATA loc # N.B. Il layer viene creato vuoto, e poi "popolato" tramite query al database
CLASS
# MINSIZE 2
# MAXSIZE 20
SYMBOL 4
SIZE 20
NAME "s00"
COLOR 255 0 255
LABEL
FORCE TRUE
OFFSET -10 -10
COLOR 255 0 255
TYPE TRUETYPE
FONT arial
MINSIZE 8
MAXSIZE 20
END
END
TOLERANCE 5
END #layer
END # end map file
