[mapserver-users] outlinesize of polygon ?
G Kelley
gk1611 at ship.edu
Thu Feb 7 08:40:37 PST 2002
I am using Mapserver 3.4, and these solutions do not work. The
first simply fills the polygon with circles, while the second
does a solid fill for the polygon. Is this a 3.4 versus 3.5
issue? How does mapserver distinguish between what to use to
draw the outline of the polygon and what to use to fill the
polygon? For example, in the first solution below, how does
mapserver know whether the polygon should be outlined using the
circle symbol or filled with the circle symbol?
Sorry if this is documented somewhere, but I could not find it in
the either the 3.3 doc or the 3.5 doc. Thanks!
-Gregg
On 31 Jan 2002, Steve Lime wrote:
>Hi Bernd: It's easy. First you need a symbol to use a a brush, this one
>works well:
>SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED TRUE
>END
>The depending on if you're drawing just the outline or the outline +
>fill you'd do something like
>SYMBOL 'circle'
>SIZE 3
>OUTLINECOLOR 0 0 0
>or
>OVERLAYSYMBOL 'circle'
>OVERLAYSIZE 3
>OVERLAYOUTLINECOLOR 0 0 0
>Steve
>Stephen Lime
>Data & Applications Manager
>Minnesota DNR
>500 Lafayette Road
>St. Paul, MN 55155
>651-297-2937
More information about the MapServer-users
