[mapserver-users] DBF Queries
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Thu Feb 7 14:34:11 EST 2002
I am giving you an example from MS 3.3 I don't know whether it is changed,
but you will get an idea of a simple query.
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
This will enable query for only this layer:
LAYER
NAME majr
TYPE LINE
STATUS ON
DATA majr
CLASS
NAME "Major Rivers"
COLOR 0 0 255
END
HEADER "majr_header.html"
FOOTER "majr_footer.html"
QUERY
TEMPLATE "majr.html"
END
TOLERANCE 5
END # end of layer object - major rivers
The majr.html is the main file here which contains attrib. from your
.dbf file:
<tr><td>[LENGTH]</td><td>[MAJR_]</td><td>[MAJR_ID]</td><td>[NAME]</td><td>[RNUM]
</td></tr>
length, name etc.. are attribs. from the dbf file.
_header.html: (only for html presentation)
<font size+1><b>Layer: majr</b></font><p>
<table cellpadding=5 cellspacing=2 border=0>
<tr bgcolor=#CCCCCC><th>LENGTH</th><th>MAJR_</th><th>MAJR_ID</th><th>NAME</th><th>RNUM</th></tr>
The footer is simply html decoration:
</table><p>
> Hello all.
> First of all, thank you for your help with the Angle labels.
> Now, I'm looking for documentation or examples about queries to DBF files.
> I use ArcView files (Shp, DBF, Shx) and i would like to show some points
> from a query in a map.
> Someone know where I can find something about it?.
> Thank you,
> Regards!
> Fran.
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
