[mapserver-users] DBF Queries
Steve Lime
steve.lime at dnr.state.mn.us
Thu Feb 7 15:32:21 PST 2002
That's what classes are for. So if you have a variable named population
and you want all features with a value greater than 5000 you'd do
something like
CLASS
NAME 'Cities with more the 5000 people in them.'
EXPRESSION ([POPULATION] > 5000)
COLOR 255 0 0
END
The net effect is that only those features matching the expression (a
query) are drawn. You can build these expressions dynamically or
hardcode them in a map file. I believe the mapfile how-to explains the
variety of expressions that you can do.
Is this sort of what you're looking for?
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Francisco Delgado" <delgadof at marn.gob.sv> 02/07/02 05:18PM >>>
Yes, it has changed. Now both TEMPLATE, HEADER and FOOTER definitions
go
inside the QUERY object of each LAYER object, but I think what Fran is
trying to do is to query a database that gets some records with
Latitude/Longitud data within the returned fields and plot them over
an
existing map. Could somebody tell us (I want to do the same) how to do
that?
Atentamente,
Francisco Jose Delgado - Director de Informatica MARN
http://www.marn.gob.sv
-----Mensaje original-----
De: owner-mapserver-users at lists.gis.umn.edu
[mailto:owner-mapserver-users at lists.gis.umn.edu]En nombre de Pushkar
Pradhan
Enviado el: Thursday, February 07, 2002 1:34 PM
Para: Francisco
CC: mapserver-users at lists.gis.umn.edu
Asunto: Re: [mapserver-users] DBF Queries
I am giving you an example from MS 3.3 I don't know whether it is
changed,
but you will get an idea of a simple query.
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
This will enable query for only this layer:
LAYER
NAME majr
TYPE LINE
STATUS ON
DATA majr
CLASS
NAME "Major Rivers"
COLOR 0 0 255
END
HEADER "majr_header.html"
FOOTER "majr_footer.html"
QUERY
TEMPLATE "majr.html"
END
TOLERANCE 5
END # end of layer object - major rivers
The majr.html is the main file here which contains attrib. from your
.dbf file:
<tr><td>[LENGTH]</td><td>[MAJR_]</td><td>[MAJR_ID]</td><td>[NAME]</td><td>[R
NUM]
</td></tr>
length, name etc.. are attribs. from the dbf file.
_header.html: (only for html presentation)
<font size+1><b>Layer: majr</b></font><p>
<table cellpadding=5 cellspacing=2 border=0>
<tr
bgcolor=#CCCCCC><th>LENGTH</th><th>MAJR_</th><th>MAJR_ID</th><th>NAME</th><t
h>RNUM</th></tr>
The footer is simply html decoration:
</table><p>
> Hello all.
> First of all, thank you for your help with the Angle labels.
> Now, I'm looking for documentation or examples about queries to DBF
files.
> I use ArcView files (Shp, DBF, Shx) and i would like to show some
points
> from a query in a map.
> Someone know where I can find something about it?.
> Thank you,
> Regards!
> Fran.
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
More information about the MapServer-users
