[mapserver-users] query error
Shaik Anwar Hussain
shussain at atsincorp.com
Tue Feb 12 15:30:16 EST 2002
Hi Friends,
I am trying to display the map by query selection. I am
gettting the following error. Does any one know how to fix this error.
msQueryByAttributes(): General error message. No query layer
defined.
I am using mapserver 3.5, windows 2000, apache.
Thanks,
Anwar
www.atsincorp.com
here is my map file.
# Start of map file - created Thu Jan 24 11:36:43 2002
NAME PAMS
SIZE 585 295
EXTENT -252600 -148033.591 274400 165545.107
UNITS meters
SHAPEPATH 'e:\pams\pamsdata/'
SYMBOLSET "C:\Program Files\Apache Group\Apache\htdocs\Symbols\symbols.sym"
# Start of web interface definition
WEB
TEMPLATE 'mapdisplay.html'
IMAGEPATH 'C:\Program Files\Apache Group\Apache\htdocs\mapimages\'
IMAGEURL '/mapimages/'
LOG 'accessLog.txt'
END #WEB
# Start of reference map
#QUERYMAP
# STATUS ON
# STYLE SELECTED
#END # QUERYMAP
REFERENCE
SIZE 136 110
#IMAGE 'C:\Program Files\Apache Group\Apache\htdocs\pams1\ref_map.jpg'
IMAGE 'C:\Program Files\Apache Group\Apache\htdocs\pams1\refmap1.jpg'
EXTENT -255899 -190124 279677 210767
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END #REFERENCE
# Start of legend
LEGEND
IMAGECOLOR 205 205 205
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
POSITION UR
END
STATUS ON
END #LEGEND
# Start of scalebar
SCALEBAR
STATUS EMBED
STYLE 0
IMAGECOLOR 255 255 255
LABEL
COLOR 0 0 0
SIZE TINY
END #LABEL
SIZE 150 4
COLOR 245 245 245
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS MILES
POSITION LR
INTERVALS 5
END #SCALEBAR
# Start of layer definitions
LAYER
NAME "municipalities"
TYPE Polygon
STATUS default
DATA 'mcd'
HEADER 'municipalities_header.html'
TEMPLATE "municipalities_query.html"
CLASS
Name 'Municipalities'
COLOR -1 -1 -1
OUTLINECOLOR 206 213 224
END # CLASS
END # LAYER
LAYER
NAME "district"
PROJECTION
"proj=poly"
"ellps=GRS80"
"lon_0=77.75w"
"lat_0=40.925n"
END
TYPE Polygon
STATUS default
DATA 'district'
HEADER 'district_header.html'
TEMPLATE "district_query.html"
CLASS
Name 'District'
COLOR -1 -1 -1
SYMBOL 'circle'
SIZE 3
OUTLINECOLOR 0 0 255
END # CLASS
END # LAYER
LAYER
NAME "county"
PROJECTION
"proj=poly"
"ellps=GRS80"
"lon_0=77.75w"
"lat_0=40.925n"
END
TYPE Polygon
STATUS default
DATA 'county'
LABELMINSCALE 70000
LABELITEM 'County__'
HEADER 'county_header.html'
TEMPLATE "county_query.html"
CLASS
LABEL
COLOR 0 0 0
ANTIALIAS True
END # LABEL
Name 'County'
COLOR -1 -1 -1
END # CLASS
END # LAYER
LAYER
NAME "stateroutes"
STATUS default
PROJECTION
"proj=poly"
"ellps=GRS80"
"lon_0=77.75w"
"lat_0=40.925n"
END
TYPE line
MAXSCALE 850000
#MINSCALE 1000
DATA 'stateroutes'
HEADER 'stateroutes_header.html'
TEMPLATE "stateroutes_query.html"
CLASS
Name 'Stateroutes'
COLOR 232 155 143
OUTLINECOLOR 0 0 0
#SYMBOL 'circle'
#SIZE 3
END # CLASS
END # LAYER
LAYER
NAME "drgs"
TYPE raster
TILEINDEX "drgtile"
TILEITEM "location"
STATUS on
MAXSCALE 150000
END # LAYER
LAYER
NAME "quads"
PROJECTION
"proj=poly"
"ellps=GRS80"
"lon_0=77.75w"
"lat_0=40.925n"
END
TYPE Polygon
STATUS on
MINSCALE 150000
DATA 'quadsheets'
HEADER 'quads_header.html'
TEMPLATE "quads_query.html"
CLASS
Name 'Quads'
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
END # CLASS
END # LAYER
LAYER
NAME "flightline"
PROJECTION
"proj=poly"
"ellps=GRS80"
"lon_0=77.75w"
"lat_0=40.925n"
END
TYPE polygon
STATUS off
DATA 'ascot_lin'
HEADER 'ascot_lin_header.html'
TEMPLATE "ascot_lin_query.html"
CLASS
Name 'Flight Lines'
#COLOR 255 0 0
SYMBOL 'circle'
SIZE 2
END # CLASS
END # LAYER
LAYER
NAME "block"
PROJECTION
"proj=poly"
"ellps=GRS80"
"lon_0=77.75w"
"lat_0=40.925n"
END
TYPE Polygon
STATUS off
DATA 'ascot_prj'
HEADER 'ascot_prj_header.html'
TEMPLATE "ascot_prj_query.html"
CLASS
Name 'Blocks'
#COLOR 152 50 32
SYMBOL 'circle'
SIZE 4
END # CLASS
END # LAYER
LAYER
NAME "photo"
PROJECTION
"proj=poly"
"ellps=GRS80"
"lon_0=77.75w"
"lat_0=40.925n"
END
TYPE Point
STATUS off
DATA 'ascot_pho'
HEADER 'ascot_pho_header.html'
TEMPLATE "ascot_pho_query.html"
CLASS
Name 'Photos'
COLOR 255 0 0
SYMBOL 'circle'
SIZE 6
END # CLASS
END # LAYER
END # MAPFILE
