[mapserver-users] query error
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Tue Feb 12 18:33:08 EST 2002
>From your map file - you have commented out the QUERYMAP section.
No clue about _query.html file, but please try this.
> Hi Friends,
> I am trying to display the map by query selection. I am
> gettting the following error. Does any one know how to fix this error.
> msQueryByAttributes(): General error message. No query layer
> defined.
> I am using mapserver 3.5, windows 2000, apache.
> Thanks,
> Anwar
> www.atsincorp.com
> here is my map file.
> # Start of map file - created Thu Jan 24 11:36:43 2002
> NAME PAMS
> SIZE 585 295
> EXTENT -252600 -148033.591 274400 165545.107
> UNITS meters
> SHAPEPATH 'e:\pams\pamsdata/'
> SYMBOLSET "C:\Program Files\Apache Group\Apache\htdocs\Symbols\symbols.sym"
> # Start of web interface definition
> WEB
> TEMPLATE 'mapdisplay.html'
> IMAGEPATH 'C:\Program Files\Apache Group\Apache\htdocs\mapimages\'
> IMAGEURL '/mapimages/'
> LOG 'accessLog.txt'
> END #WEB
> # Start of reference map
> #QUERYMAP
> # STATUS ON
> # STYLE SELECTED
> #END # QUERYMAP
> REFERENCE
> SIZE 136 110
> #IMAGE 'C:\Program Files\Apache Group\Apache\htdocs\pams1\ref_map.jpg'
> IMAGE 'C:\Program Files\Apache Group\Apache\htdocs\pams1\refmap1.jpg'
> EXTENT -255899 -190124 279677 210767
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END #REFERENCE
> # Start of legend
> LEGEND
> IMAGECOLOR 205 205 205
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> POSITION UR
> END
> STATUS ON
> END #LEGEND
> # Start of scalebar
> SCALEBAR
> STATUS EMBED
> STYLE 0
> IMAGECOLOR 255 255 255
> LABEL
> COLOR 0 0 0
> SIZE TINY
> END #LABEL
> SIZE 150 4
> COLOR 245 245 245
> BACKGROUNDCOLOR 0 0 0
> OUTLINECOLOR 0 0 0
> UNITS MILES
> POSITION LR
> INTERVALS 5
> END #SCALEBAR
> # Start of layer definitions
> LAYER
> NAME "municipalities"
> TYPE Polygon
> STATUS default
> DATA 'mcd'
> HEADER 'municipalities_header.html'
> TEMPLATE "municipalities_query.html"
> CLASS
> Name 'Municipalities'
> COLOR -1 -1 -1
> OUTLINECOLOR 206 213 224
> END # CLASS
> END # LAYER
> LAYER
> NAME "district"
> PROJECTION
> "proj=poly"
> "ellps=GRS80"
> "lon_0=77.75w"
> "lat_0=40.925n"
> END
> TYPE Polygon
> STATUS default
> DATA 'district'
> HEADER 'district_header.html'
> TEMPLATE "district_query.html"
> CLASS
> Name 'District'
> COLOR -1 -1 -1
> SYMBOL 'circle'
> SIZE 3
> OUTLINECOLOR 0 0 255
> END # CLASS
> END # LAYER
> LAYER
> NAME "county"
> PROJECTION
> "proj=poly"
> "ellps=GRS80"
> "lon_0=77.75w"
> "lat_0=40.925n"
> END
> TYPE Polygon
> STATUS default
> DATA 'county'
> LABELMINSCALE 70000
> LABELITEM 'County__'
> HEADER 'county_header.html'
> TEMPLATE "county_query.html"
> CLASS
> LABEL
> COLOR 0 0 0
> ANTIALIAS True
> END # LABEL
> Name 'County'
> COLOR -1 -1 -1
> END # CLASS
> END # LAYER
> LAYER
> NAME "stateroutes"
> STATUS default
> PROJECTION
> "proj=poly"
> "ellps=GRS80"
> "lon_0=77.75w"
> "lat_0=40.925n"
> END
> TYPE line
> MAXSCALE 850000
> #MINSCALE 1000
> DATA 'stateroutes'
> HEADER 'stateroutes_header.html'
> TEMPLATE "stateroutes_query.html"
> CLASS
> Name 'Stateroutes'
> COLOR 232 155 143
> OUTLINECOLOR 0 0 0
> #SYMBOL 'circle'
> #SIZE 3
> END # CLASS
> END # LAYER
> LAYER
> NAME "drgs"
> TYPE raster
> TILEINDEX "drgtile"
> TILEITEM "location"
> STATUS on
> MAXSCALE 150000
> END # LAYER
> LAYER
> NAME "quads"
> PROJECTION
> "proj=poly"
> "ellps=GRS80"
> "lon_0=77.75w"
> "lat_0=40.925n"
> END
> TYPE Polygon
> STATUS on
> MINSCALE 150000
> DATA 'quadsheets'
> HEADER 'quads_header.html'
> TEMPLATE "quads_query.html"
> CLASS
> Name 'Quads'
> COLOR -1 -1 -1
> OUTLINECOLOR 0 0 0
> END # CLASS
> END # LAYER
> LAYER
> NAME "flightline"
> PROJECTION
> "proj=poly"
> "ellps=GRS80"
> "lon_0=77.75w"
> "lat_0=40.925n"
> END
> TYPE polygon
> STATUS off
> DATA 'ascot_lin'
> HEADER 'ascot_lin_header.html'
> TEMPLATE "ascot_lin_query.html"
> CLASS
> Name 'Flight Lines'
> #COLOR 255 0 0
> SYMBOL 'circle'
> SIZE 2
> END # CLASS
> END # LAYER
> LAYER
> NAME "block"
> PROJECTION
> "proj=poly"
> "ellps=GRS80"
> "lon_0=77.75w"
> "lat_0=40.925n"
> END
> TYPE Polygon
> STATUS off
> DATA 'ascot_prj'
> HEADER 'ascot_prj_header.html'
> TEMPLATE "ascot_prj_query.html"
> CLASS
> Name 'Blocks'
> #COLOR 152 50 32
> SYMBOL 'circle'
> SIZE 4
> END # CLASS
> END # LAYER
> LAYER
> NAME "photo"
> PROJECTION
> "proj=poly"
> "ellps=GRS80"
> "lon_0=77.75w"
> "lat_0=40.925n"
> END
> TYPE Point
> STATUS off
> DATA 'ascot_pho'
> HEADER 'ascot_pho_header.html'
> TEMPLATE "ascot_pho_query.html"
> CLASS
> Name 'Photos'
> COLOR 255 0 0
> SYMBOL 'circle'
> SIZE 6
> END # CLASS
> END # LAYER
> END # MAPFILE
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
