[mapserver-users] symbols indexed by an attribute
    Pushkar Pradhan
    pushkar at ERC.MsState.Edu
    Wed Feb 13 09:51:02 PST 2002
Thanks Steve,
I am now trying to built mapscript with perl, but there doesn't seem to be
any documentation on that. Can anyone point me if there is docum.
available on this, otherwise I will try to use php/mapscript?
I welcome suggestions and your experience from everybody about perl vs.
php with mapscript.
On Tue, 12 Feb 2002, Stephen Woodbridge wrote:
> I think you need to use mapscript then it should not be a problem. Using
> mapscript implies that you build your web navigation tool using the Perl
> or PHP version of mapscript.
> -Steve
> Pushkar Pradhan wrote:
> > Hi everyone,
> > My team wants me to create markers, lines and shades depend. upon
> > particular attribs. from the shapefile.
> > Eg. they created an attr. Shade_sym which is a no., that no. should be
> > used to fetch symbol from the map file e.g. if Shade_sym = 29, the 29th
> > symbol from the map file must be used.
> > I do the foll. to accomplish the task:
> >    CLASSITEM 'Shade_sym'
> >    CLASS
> >      NAME "sym = 29"
> >      EXPRESSION ([Shade_sym] EQ 29)
> >      SYMBOL 29
> >      SIZE 2
> >      COLOR 114 24 124
> >    END
> > Okay I think this is the optimal way, unless any body has other ideas.
> > But they also want me to read COLOR AND/OR SIZE for the symbol from a
> > file, e.g. the foll. is such a file, the first no. being the symbol no.:
> > # value red green blue
> > 1 255 250 250
> > 2 248 248 255
> > 3 245 245 245
> > 4 220 220 220
> > 5 255 250 240
> > Thus I should be able to use the attr. Shade_sym's value 29 to index into
> > this file and assign the RGB values to COLOR?
> > Is there a way to do this? I've tried to be very brief.
> > Thanks,
> > PUSHKAR S. PRADHAN
> > Research Assistant
> > MISSISSIPPI STATE UNIVERSITY,
> > STARKVILLE, MS 39759.
> > Engineering Research Center
> > Box 9627
> > Mississippi State, MS 39762-9627
PUSHKAR S. PRADHAN
Research Assistant
Box 9627
More information about the MapServer-users
