[mapserver-users] newbie question :
Stephane MOREL
stephane.morel at vanoise.com
Thu Feb 14 04:42:09 EST 2002
Thank you for all your answer :
I guess several mistakes has been made :
First, of course the line IMAGEURL was uncommented
Second, I have downloaded mapserver 3.4 and the demo is version 3.3.
I guess the best way is to reinstall all correctly
Thanks again
Pushkar Pradhan a écrit :
> You've commented out your image url path:
> > #IMAGEURL "/tmp/"
> > #IMAGEURL "/ms_demo/"
> You need to point to your directory containing the images, and the path is
> from the htdocs dir. (if it is apache).
> > Hi
> > I've installed mapserver 3.4 on linux machine running Suse 7.2
> > Every things works perfectly well. When I run http://myserver/cgi-bin/mapserv,
> > I've got the following answer : No query information to decode. QUERY_STRING is
> > set, but empty.
> > If I understand well it means that mapserver is correctly installed
> > Am I right ?
> > I've downloaded the demo. When I run the demo_init.html I can see the fisrt
> > window and when I click on the initialize button I can see the demo interface
> > but not the map.
> > When I look in the directory where I put the mapserver demo I can see that the
> > DEMO1215465488.gif has been created.
> > So why can I can't see the gif file in my browser ?
> > My demo.map :
> > # Start of map file
> > NAME DEMO
> > STATUS ON
> > SIZE 600 600
> > SYMBOLSET symbols/symbols.sym
> > EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897
> > UNITS METERS
> > SHAPEPATH "data"
> > IMAGECOLOR 255 255 255
> > # Start of web interface definition
> > WEB
> > HEADER demo_header.html
> > TEMPLATE demo.html
> > FOOTER demo_footer.html
> > MINSCALE 1000
> > MAXSCALE 1550000
> > # IMAGEPATH "/usr/local/apache/htdocs/tmp/"
> > IMAGEPATH "/home/site_intranet/mapserver/ms_demo/"
> > #IMAGEURL "/tmp/"
> > # LOG "demo.log"
> > END and the rest of the file
> > My demo_init.html :
> > <html>
> > <head><title>MapServer Demo Interface</title></head>
> > <body bgcolor="#FFFFFF">
> > <center><h2>MapServer Demo Interface</h2></center>
> > <p><hr><p>
> > Click on the initialize button to fire up the demo with 3 layers turned on will
> > be accessible for browsing. The
> > data are of Itasca County, MN and were derived, for the most part, from USGS
> > 1:24,000 quadrangles. Some things to note are:
> > <form method=GET action="/cgi-bin/mapserv">
> > <input type="hidden" name="map"
> > value="/home/site_intranet/mapserver/ms_demo/demo.map">
> > <input type="hidden" name="layer" value="lakes">
> > <input type="hidden" name="layer" value="streams">
> > <input type="hidden" name="zoomsize" value=2>
> > <center><input type="submit" value="Initialize"></center>
> > </form>
> > <p><hr><p>
> > </body></html>
> > Any suggestions ?
> > TIA
> > Stef
> PUSHKAR S. PRADHAN
> Research Assistant
> MISSISSIPPI STATE UNIVERSITY,
> STARKVILLE, MS 39759.
> Engineering Research Center
> Box 9627
> Mississippi State, MS 39762-9627
Type: text/x-vcard
Desc: Carte pour Stephane MOREL
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020214/fb966280/stephane.morel.vcf
