[mapserver-users] Itemquery problem
Müller Ulrich
Ulrich.Mueller at bd.so.ch
Thu Feb 14 09:17:36 EST 2002
Hi Listers
This may be one of the most often asked questions: Why do I not get the
correct result from ITEMQUERY?
I have a polygon layer (Shape) named parznum. It has about 50000 records and
a numeric field named sys_obid. Among those 50000 records there is exactly
one with sys_obid=25489. Now I want to run an itemquery to find this record
With JavaScript I create the following URL:
...&qlayer=parznum&mode=itemquery&item=sys_obid&value=25489&...
I get no results.
I also tried it with a regular expression:
...&qlayer=parznum&mode=itemquery&item=sys_obid&value=^25489$&...
Again - no results.
As a test I then used this url:
...&qlayer=parznum&mode=itemquery&item=sys_obid&value=489&...
As result I get a record with sys_obid=48966. But that is not what I want.
Any ideas?
Uli
LAYER
NAME parznum
STATUS ON
DATA "kva/av93/liegentest"
TYPE POINT
CLASSITEM "sys_obid"
QUERYITEM "sys_obid"
CLASS
END
QUERY
TEMPLATE
"http://intraso.so.ch/sogis/adresse.php?applic_id=[applic_id]&shpmid=[shpmid
END
END
END # Map File
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020214/4182339d/ISO-8859-1QMFCller_Ulrich2Evcf.obj
