[mapserver-users] symbols indexed by an attribute
Jamie Smedsmo
jsmedsmo at gis.umn.edu
Thu Feb 14 14:54:23 EST 2002
We do have a per/mapscript document coming. Hopefully we'll have it
online sometime next week.
Jamie
Doug Williams wrote:
>Beware: that documentation is for Version 3.3 perl mapscript.
>On Wednesday 13 February 2002 11:08, Stephen Woodbridge wrote:
>>http://mapserver.gis.umn.edu/mapscript.html
>>Pushkar Pradhan wrote:
>>>Thanks Steve,
>>>I am now trying to built mapscript with perl, but there doesn't seem to
>>>be any documentation on that. Can anyone point me if there is docum.
>>>available on this, otherwise I will try to use php/mapscript?
>>>I welcome suggestions and your experience from everybody about perl vs.
>>>php with mapscript.
>>>On Tue, 12 Feb 2002, Stephen Woodbridge wrote:
>>>>I think you need to use mapscript then it should not be a problem.
>>>>Using mapscript implies that you build your web navigation tool using
>>>>the Perl or PHP version of mapscript.
>>>>-Steve
>>>>>Hi everyone,
>>>>>My team wants me to create markers, lines and shades depend. upon
>>>>>particular attribs. from the shapefile.
>>>>>Eg. they created an attr. Shade_sym which is a no., that no. should
>>>>>be used to fetch symbol from the map file e.g. if Shade_sym = 29, the
>>>>>29th symbol from the map file must be used.
>>>>>I do the foll. to accomplish the task:
>>>>> CLASSITEM 'Shade_sym'
>>>>> CLASS
>>>>> NAME "sym = 29"
>>>>> EXPRESSION ([Shade_sym] EQ 29)
>>>>> SYMBOL 29
>>>>> SIZE 2
>>>>> COLOR 114 24 124
>>>>> END
>>>>>Okay I think this is the optimal way, unless any body has other
>>>>>ideas. But they also want me to read COLOR AND/OR SIZE for the symbol
>>>>>from a file, e.g. the foll. is such a file, the first no. being the
>>>>>symbol no.: # value red green blue
>>>>>1 255 250 250
>>>>>2 248 248 255
>>>>>3 245 245 245
>>>>>4 220 220 220
>>>>>5 255 250 240
>>>>>Thus I should be able to use the attr. Shade_sym's value 29 to index
>>>>>into this file and assign the RGB values to COLOR?
>>>>>Is there a way to do this? I've tried to be very brief.
>>>>>Thanks,
>>>>>--------- PUSHKAR S. PRADHAN
>>>>>Research Assistant
>>>>>MISSISSIPPI STATE UNIVERSITY,
>>>>>STARKVILLE, MS 39759.
>>>>>Engineering Research Center
>>>>>Box 9627
>>>>>Mississippi State, MS 39762-9627
>>>Research Assistant
>>>Box 9627
