[mapserver-users] PHP/Mapscript Question
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Feb 14 22:27:33 EST 2002
Dan, et al,
In PHP/Mapscript 3.5, I want to add a marker to my map. With the CGI
interface I did something like:
layer=marker&map_marker_feature=new&map_marker_feature_points={LON}+{LAT}&map_marker_feature_text={LABEL}
The map file section for is below.
I am correct that PHP/Mapscript does not have access to the FEATURE
Objects?
It seems that the way I should go about doing this using code based on
gmap75 I would be something like this in GMapDrawMap():
$img = $gpoMap->draw();
if ($HTTP_FORM_VARS["mx"])
$dfmx = doubleval($HTTP_FORM_VARS["mx"]);
$dfmy = doubleval($HTTP_FORM_VARS["my"]);
$sfmtxt = $HTTP_FORM_VARS["mtxt"];
$mlay = $gpoMap->getlayerbyname("marker");
$mlay->set("status", 1);
$pnt = ms_newPointObj();
$pnt->setXY($dfmx, $dfmy);
$pnt->draw($gpoMap, $mlay, $img, 0, $sftxt);
where layer marker in my map file would be defined like:
LAYER
NAME marker
TYPE POINT
STATUS OFF
CLASS
NAME "User Marker"
#TEXT "HERE"
SYMBOL 'marker'
COLOR 0 0 0
LABEL
TYPE TRUETYPE
FONT arial-bold
BUFFER 4
SIZE 8
POSITION AUTO
COLOR 0 0 0
BACKGROUNDCOLOR 255 255 204
END
END
#FEATURE
# POINTS x y
#END
END
Does this make sense?
Is there a better way to do this?
Thanks,
-Steve Woodbridge
