[mapserver-users] Zooming Strangeness
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Feb 15 09:04:32 EST 2002
Hi all,
I am using a modified version of GMap75 which is working great, but I
have run into a strange problem related to zooming which may or may not
be related to the GMap code. I am using
EXTENT -180.0 -90.0 180.0 90.0
UNITS DD
PROJECTION
"proj=latlong"
END
and all my data is in lat/long coordinates.
Here are two of the symptons:
1) I am zoom in to +-0.013 degrees (approx. 0.75 miles over 600 pix)
with a marker in the center of the image. I zoom out using rosa and the
GMap code and my marker is still at the same lat/long, the image zooms
out but has shifted so that the marker is now center on the lower left
quarter of the image like (M => marker position):
+ + < before + +
+ M + + +
+ + after > + M +
If I recenter/pan (using rosa) and clicking on the marker it moves
correctly to the center.
2) I am zoomed to the full extents of the map and I try to zoom in on
roughly a 4 state area using rosa and the GMap code. I get the zoom but
the rectangle that is zoomed to is positioned significantly below the
rectangle I selected. For example, I zoom in on Massachussetts and I end
up somewhere in the Carribean. Likewise, is I try to pan to the correct
location using the reference map, I have to click up in Canada to end up
in Mass. I think there is also a horizontal shift like in 1) above so
these are both probably the same problem only magnified by scale.
Anyone have any ideas? I this an artifact that GMap75 was designed
around different assumptions regard the output projection?
You can try it out at
http://swoodbridge.com/cgi-bin/geo
http://swoodbridge.com/web2/nmap
I only have Tiger data loaded for the eastern half of the US.
Thanks for the help,
Stephen Woodbridge
