Hi Francisco,
Are you trying to add it to an existing map that works?
Do you have .jfw file to go along with the image? I mean, does the image
have any coordinates associated with it?
If not, then you will that the image falls outside of the map area.
Someone else can probably give you direction around how to place an image
at a specific location on the map viewing window. Is the image for the map
or just a logo or something like that which you want added on top of the
map?
Tyler
Francisco
<fgclaram at alu-ab.uclm.es> To: mapserver-users at lists.gis.umn.edu
Sent by: cc:
owner-mapserver-users at lists.g Fax to:
is.umn.edu Subject: [mapserver-users] Raster Image
02/15/2002 02:55 AM
Hello all,
I'm trying to load a Raster image (jpg) into a map.
this is a piece of my code:
LAYER
NAME "ab"
TYPE RASTER
STATUS ON
MAXSCALE 4000
CLASS
COLOR 0 0 0
END
END
But it doesn't work. And I don't know why.
There aren't any error message.
What's the matter?. Could you help me?
Thanks,
