[mapserver-users] byacc error on make from CVS
Tyler Mitchell
TMitchell at lignum.com
Tue Feb 19 11:00:14 EST 2002
Hi Frank, thanks for your suggestion. I had found some other direction and
was successful.
FYI
In my Makefile, I modified the line defining YACC and set it to bison
instead of byacc. It now works fine.
Frank Koormann
<frank.koormann at intevation.de To: Tyler Mitchell <TMitchell at lignum.com>
> cc: mapserver-users at lists.gis.umn.edu
Sent by: Fax to:
owner-mapserver-users at lists.g Subject: Re: [mapserver-users] byacc error on make from CVS
is.umn.edu
02/19/2002 02:38 AM
Tyler,
* Tyler Mitchell (TMitchell at lignum.com) [020219 02:17]:
> I'm trying to build mapserver from CVS and I get this error when I run
> make:
> >byacc -p msyy -d -omapparser.c mapparser.y
> >usage: byacc [-dlrtv] [-b file_prefix] [-p symbol_prefix] filename
> Can anyone comment on this for me - do I need to provide more
information?
looks as if your byacc does not support to "-o" option to specify an
output file. AFAIR mapserver build process is relatively strict bound to
the GNU version of yacc, bison.
A try would be to indentify the line in the generated makefile and
edit it to something like
byacc -p msyy -d mapparser.y > mapparser.c
Regards,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
