[mapserver-users] What's wrong with this string?
Steve Lime
steve.lime at dnr.state.mn.us
Wed Feb 20 08:46:24 EST 2002
Imgext is only used to describe an existing image displayed by mapserver
and needs x,y coordinates (in image units) to be useful. I think what
you want to use mapext instead. Mapext refers to the extent of the map
to be created and is the standard way to initialize an application.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Lyndon Zimmermann <lyndon.zimmermann at adelaide.edu.au> 02/19/02 21:55
PM >>>
I'm reworking an enquiry front end, and currently generate an initiate
string:
http://sg211.gisca.adelaide.edu.au/cgi-bin/mapserv/mapserv?map=..%2Fhtdocs%2Fau_afs_mapserver%2Fau_afs_nojava.map&mode=browse&layer=state_boundaries&zoomsize=2&imgext=855342.0+-4343315.0+1458169.0+-3768371.0&resources=infield&pop=999&roads=999&elec=999
It appears to ignore the imgext, and just uses the defaults. Any
clues? The values are an Albers projection, I obtained by zooming to my
region of interest and copying the command string that produced it.
Lyndon Zimmermann
Lyndon Zimmermann
BE (Mech Adelaide) Grad Dip Bus Admin (UniSA)
LOW RAINFALL AGROFORESTRY RESEARCH UNIT
Affiliated with the CRC for Plant Based Management of Dryland Salinity
University of Adelaide Department of Agronomy and Farming Systems
Physical address: Hannaford Building (via Gate 3) Waite Campus, South
Australia
Postal: Adelaide University, PMB1 Glen Osmond, SA 5064, Australia
Dir (Soil and Water) +61-8-8303 6571 Mob 0414 91 4577
Fax +61-8-8303 6717 email lyndon.zimmermann at adelaide.edu.au
Bionergy Atlas Website:
http://www.gisca.adelaide.edu.au/~lzimmerm/bioenergy_atlas/atlas_index.html
Unless otherwise stated, the content of this message and attachments may
be forwarded or quoted, with due acknowledgement. No representation is
made that this email is free of viruses. Virus scanning is recommended
and is the responsibility of the recipient.
