[mapserver-users] Java Wrapper for mapserver
Harald Wehr
hwehr at hs-harz.de
Thu Feb 21 01:49:28 EST 2002
Steve Lime wrote:
> I've talked to the PHP folks and we will add an imageObj to the main mapscript to maintain compatability between them.
> One other thing, I've had no problem getting the shared library to compile but am having a heck of time compiling the java class files. With swig I do a:
> swig -java -shadow -package mapscript mapscript.i
> but when compiling even a simple class like colorObj.java javac whines about not being able to resolve mapscript.whatever. Seems to be hung on the package name. Anyway, I'm not a java guru and am trying to write a Makefile based procedure to add to the distribution. I realize there are other hacks that have to be made to the .java files (will try to script those) but obviously I'm doing something stupid if I can't even get the most simple file to build. Note that I'm moving all of the .java files into their own directory apart from the C stuff. Ideas?
Hi Steve,
can you give the exact error message? When you "swigg" mapscript to
java-files as package "mapscript" they all must be in a directory
called "mapscript". Then you compile with:
javac mapscript/*.java
and it should work.
Harald
