[mapserver-users] compilation problem
Carsten Vogt
vogt at Hamburg.BAW.DE
Fri Feb 22 02:02:10 EST 2002
Oops, right!
Here is the complete output:
cd mapscript/php3; make; cd ../..
make[1]: Entering directory `/opt/src/mapserver_3.5/mapscript/php3'
gcc gcc -I. -I.. -fPIC -O2 -Wall -DCOMPILE_DL=1 -DPHP4
-DUSE_WMS -DUSE_PRO
J -DUSE_PROJ_API_H -DUSE_EPPL -DUSE_TIFF -DUSE_GD_PNG -DUSE_GD_JPEG
-DUSE_GD_W
BMP -DUSE_GD_TTF
-DUSE_JPEG -I/opt/src/mapserver_3.5 -I/usr/local/inclu
de -I/opt/src/php-4.1.0 -I/opt/src/php-4.1.0/dl -I/opt/src/php-4.1.0/main
-I/o
pt/src/php-4.1.0/Zend -I/opt/src/php-4.1.0/include
-I/opt/src/php-4.1.0/TSRM -I/
usr/local/apache-1.3.22/include -c -o php_mapscript_util.o php_mapscript_util.c
gcc: cannot specify -o with -c or -S and multiple compilations
make[1]: *** [php_mapscript_util.o] Error 1
make[1]: Leaving directory `/opt/src/mapserver_3.5/mapscript/php3'
Regards,
Carsten Vogt
At 21.02.2002 13:40 -0500, you wrote:
>Carsten Vogt wrote:
> > I just tried to compile the actual mapserver (MapServer 3.5 (12/18/01),
> > downloaded from Mapserver Website) on Solaris 8 (Sun OS 5.8, gcc 2.95.3)
> > with all required libraries installed (at least I think so :-) and
> > configure with --with-apxs --with-php=/path/to/php/source and get the
> > following error:
>This is probably due to a problem in the mapscript/php3/Makefile. But
>in order to suggest a solution we need more information... we would need
>to see the last command (starting with gcc) that got executed by the
>Makefile before the error message.
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
Dipl.-Geogr. Carsten Vogt
Tel.: 040 - 81908 - 345
Fax: 040 - 81908 - 373
vogt at hamburg.baw.de
http://nokis.baw.de/
Bundesanstalt fuer Wasserbau
- Aussenstelle Kueste -
Wedeler Landstrasse 157
DE - 22559 Hamburg
