[mapserver-users] Raster reprojection
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Sun Feb 24 01:47:50 EST 2002
You should have to recompile mapserver with the --without-tiff option
and --with-gdal=/path/to/gdal-config
Otherwise what happens is that when MS comes across the TIFF img. it calls
the TIFF libs. and GDAL libs. will never be called.
> Hello.
> I'm having a problem with ms.
> >From time to time, I get an error:
> Warning: MapServer Error in msDrawRasterLayer( TIFF ): Raster reprojection
> supported only with the GDAL library. in
> /usr/local/apache/htdocs/sig/templates/mapa_form.php on line 234
> I've read in the mail-list, and Frank Warmerdam says that it is necessary to
> reconfigure without tiff support.
> Reconfigure what? GD? MS? PHP?
> My configure options:
> PHP:
> ./configure --with-dbase=yes --with-system-regex --with-png=yes --without-ttf
> --with-apxs=/usr/local/apache/bin/apxs --with-mysql --with-pgsql
> --with-config-file-path=/etc
> MS:
> ./configure --with-gd=/programas/gd-1.8.4 --with-php=/programas/php-4.0.6
> --with-apxs=/usr/local/apache/bin/apxs --with-sde --with-ttf
> Thanks a lot,
> Vladimir Guzmán
> www.main-task.com
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
