[mapserver-users] Highlighting a found shape through it's index
Azimuth, Erwin Perik
perik at azimuth.nl
Mon Feb 25 06:40:29 EST 2002
Hi All,
i'm still having difficulties showing only the queryd object (highlighted).
From a database-search i have the index of the shape.
Creating new extents so new created image is zoomed in to the object is no
problem, but i do not seem to see the logic of the mapscript objects.
Now i have the following:
This is supposed to be showing a map with the queried object highlighted.
In the map file (see below) i have a dummy layer which should be used for
the highlight
Input (GLOBAL) is:
--> qlayer (name = park)
--> index (the dbf-file index of the queried object)
// Start with default map
$NewMap = ms_newMapObj("track4.map");
// Create shapefile object.
$shapeFileObj = ms_newShapeFileObj($ShapefileName, -1 );
// Create shape object
$oShape = ms_newShapeObj(-1);
// Show the queried object, by turning ON a dummy layer:
// Default layername for this is --> layer + 'Query' --> eg. parkQuery
$QueryLayerName = $qlayer . 'Query';
$poLayer = $NewMap->getlayerbyname($QueryLayerName);
// Retrieve shape into shape object.
$oShape = $shapeFileObj->getShape($value -1); // index from dbf-file (-1 !)
// Add shape
$shapeFileObj->addShape($oShape);
// Turn dummy layer on
$poLayer->set("status", 1);
// Draw the queried object
$Newimg = $NewMap->drawQuery();
$Newurl = $Newimg->saveWebImage($Newimg, 0, 0, -1);
echo"<INPUT TYPE=image SRC=$Newurl NAME=zoommap WIDTH=$NewMap->width
HEIGTH=$NewMap->height>\n";
MAP FILE: Dummy-layer
LAYER
NAME "parkQuery" # This layer is to Highlight the queried object!
TYPE POLYGON
STATUS OFF
DATA park
CLASS
NAME "parkQuery"
COLOR 0 0 255
OUTLINECOLOR 120 120 120
TEMPLATE "ttt_query.html"
END
END # Layer
In the list and in the original Gmap example i have not found a way to get
the wanted result.
Maybe the outcome (hopefull ;-) ) could be interesting for the HOW-TO
section of mapscript.
Thanks in advance for any input,
Erwin
