[mapserver-users] Sequence of layers
Lowell Filak
lfilak at medinaco.org
Wed Feb 27 10:13:12 EST 2002
Being that a mapfile is just text, couldn't you dynamically create a map file with the layers you want in the order you want them and use that map file as the basis for a $map=new mapObj('temp_name.map'); call?
Lowell F.
The following message was sent by Lyndon Zimmermann <lyndon.zimmermann at adelaide.edu.au> on Wed, 27 Feb 2002 14:29:27 +1030.
> Greetings all,
> We're running straight Mapserver for the Bioenergy Atlas for Australia
> and one of the limitations I see is the inability (I presume I'm right
> here) to control the sequence of presentation of layers, aside from the
> mapfile. Aside from multiple .map files, what options exist for
> altering this sequence?
> Ditto theme colours and hash.
> Regards,
> Lyndon Z
> Lyndon Zimmermann
> BE (Mech Adelaide) Grad Dip Bus Admin (UniSA)
> LOW RAINFALL AGROFORESTRY RESEARCH UNIT
> Affiliated with the CRC for Plant Based Management of Dryland Salinity
> University of Adelaide Department of Agronomy and Farming Systems
> Physical address: Hannaford Building (via Gate 3) Waite Campus, South
> Australia
> Postal: Adelaide University, PMB1 Glen Osmond, SA 5064, Australia
> Dir (Soil and Water) +61-8-8303 6571 Mob 0414 91 4577
> Fax +61-8-8303 6717 email lyndon.zimmermann at adelaide.edu.au
> Bionergy Atlas Website:
> http://www.gisca.adelaide.edu.au/~lzimmerm/bioenergy_atlas/atlas_index.html
> Unless otherwise stated, the content of this message and attachments may
> be forwarded or quoted, with due acknowledgement. No representation is
> made that this email is free of viruses. Virus scanning is recommended
> and is the responsibility of the recipient.
