[mapserver-users] Sequence of layers
Lowell Filak
lfilak at medinaco.org
Wed Feb 27 11:29:03 PST 2002
And for Perl?
The following message was sent by Assefa Yewondwossen <assefa at dmsolutions.ca> on Wed, 27 Feb 2002 14:06:36 -0500.
> Hi there,
> There has been an addition recently to php/mapscript of two sets of functions
> relative to layer's sequence : (these functions applies on the map object)
> - boolean setlayersdrawingorder(array layeryindex)
> Set the layer's order array. The argument passed must be a valid array
> with all the layer's index.
> Return TRUE on success or else FALSE.
> - array getlayersdrawingorder()
> Return an array containing layer's index in the order which they are
> drawn.
> and
> boolean moveLayerUp(int layerindex)
> Move layer up in the hierarcy of drawing.
> boolean moveLayerDown(int layerindex)
> Move layer down in the hierarcy of drawing.
> The idea is to change the layer's order when the map is drawn or saved.
> Later,
> Steve Lime wrote:
> > That's one way. There is a mechanism in the mapserver structures for
> > doing this but I don't
> > think it's been exposed through any of the scripting languages. I'll
> > let the folks at DMSolutions
> > expand on that if they care to.
> > Steve
> > Stephen Lime
> > Data & Applications Manager
> > Minnesota DNR
> > 500 Lafayette Road
> > St. Paul, MN 55155
> > 651-297-2937
> > >>> "Lowell Filak" <lfilak at medinaco.org> 02/27/02 10:51AM >>>
> > Alternate solution:?
> > http://mapserver.gis.umn.edu/wilma/mapserver-users/0102/msg00010.html
> > Lowell F.
> > The following message was sent by Lyndon Zimmermann
> > <lyndon.zimmermann at adelaide.edu.au> on Wed, 27 Feb 2002 14:29:27
> > +1030.
> > > Greetings all,
> > > We're running straight Mapserver for the Bioenergy Atlas for
> > Australia
> > > and one of the limitations I see is the inability (I presume I'm
> > right
> > > here) to control the sequence of presentation of layers, aside from
> > the
> > > mapfile. Aside from multiple .map files, what options exist for
> > > altering this sequence?
> > > Ditto theme colours and hash.
> > > Regards,
> > > Lyndon Z
> > > Lyndon Zimmermann
> > > BE (Mech Adelaide) Grad Dip Bus Admin (UniSA)
> > > LOW RAINFALL AGROFORESTRY RESEARCH UNIT
> > > Affiliated with the CRC for Plant Based Management of Dryland
> > Salinity
> > > University of Adelaide Department of Agronomy and Farming Systems
> > > Physical address: Hannaford Building (via Gate 3) Waite Campus,
> > South
> > > Australia
> > > Postal: Adelaide University, PMB1 Glen Osmond, SA 5064, Australia
> > > Dir (Soil and Water) +61-8-8303 6571 Mob 0414 91 4577
> > > Fax +61-8-8303 6717 email lyndon.zimmermann at adelaide.edu.au
> > > Bionergy Atlas Website:
> > http://www.gisca.adelaide.edu.au/~lzimmerm/bioenergy_atlas/atlas_index.html
> > > Unless otherwise stated, the content of this message and attachments
> > may
> > > be forwarded or quoted, with due acknowledgement. No representation
> > is
> > > made that this email is free of viruses. Virus scanning is
> > recommended
> > > and is the responsibility of the recipient.
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056
> Fax: (613) 565-0925
More information about the MapServer-users
