[mapserver-users] Zooming Strangeness
Assefa Yewondwossen
assefa at dmsolutions.ca
Thu Feb 28 10:55:07 EST 2002
Hi there,
I am not sure what the problem is but I am going to look at it this
afternoon.
Stephen, is it possible for you to send me the necessary files (map, phpcode,
data ...) so I can try to reprodue the problem here.
Later,
Stephen Woodbridge wrote:
> I never saw any response to this post, I am somewhat at a loss on this.
> Does anyone have any ideas.
> DM Solutions guys,
> Does the code in GMap that maps from pixel to map units work if I am
> using lat/long data instead of meters like the original app was using?
> Would it account for the symptoms I am seeing?
> Any help would be appreaciated,
> -Steve W.
> > Hi all,
> > I am using a modified version of GMap75 which is working great, but I
> > have run into a strange problem related to zooming which may or may not
> > be related to the GMap code. I am using
> > EXTENT -180.0 -90.0 180.0 90.0
> > UNITS DD
> > PROJECTION
> > "proj=latlong"
> > END
> > and all my data is in lat/long coordinates.
> > Here are two of the symptons:
> > 1) I am zoom in to +-0.013 degrees (approx. 0.75 miles over 600 pix)
> > with a marker in the center of the image. I zoom out using rosa and the
> > GMap code and my marker is still at the same lat/long, the image zooms
> > out but has shifted so that the marker is now center on the lower left
> > quarter of the image like (M => marker position):
> > + + < before + +
> > + M + + +
> > + + after > + M +
> > If I recenter/pan (using rosa) and clicking on the marker it moves
> > correctly to the center.
> > 2) I am zoomed to the full extents of the map and I try to zoom in on
> > roughly a 4 state area using rosa and the GMap code. I get the zoom but
> > the rectangle that is zoomed to is positioned significantly below the
> > rectangle I selected. For example, I zoom in on Massachussetts and I end
> > up somewhere in the Carribean. Likewise, is I try to pan to the correct
> > location using the reference map, I have to click up in Canada to end up
> > in Mass. I think there is also a horizontal shift like in 1) above so
> > these are both probably the same problem only magnified by scale.
> > Anyone have any ideas? I this an artifact that GMap75 was designed
> > around different assumptions regard the output projection?
> > You can try it out at
> > http://swoodbridge.com/cgi-bin/geo
> > http://swoodbridge.com/web2/nmap
> > I only have Tiger data loaded for the eastern half of the US.
> > Thanks for the help,
> > Stephen Woodbridge
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056
Fax: (613) 565-0925
