[mapserver-users] GDAL compile errors
Puneet Kishor
pkishor at GeoAnalytics.com
Wed Feb 27 11:51:58 EST 2002
Frank, others,
yesterday I tried to compile GDAL on my MacOS X iBook using gcc... I was not
successful. I am reproducing the few lines of seemingly error messages from
the terminal buffer... any guidance would be much appreciated.
tia.
pk
ranlib ./gdal.a
ranlib: file: ./gdal.a(pnggccrd.o) has no symbols
ranlib: file: ./gdal.a(pngvcrd.o) has no symbols
ranlib: file: ./gdal.a(tif_pixarlog.o) has no symbols
ranlib: file: ./gdal.a(cpl_vsil_unix_stdio_64.o) has no symbols
cc -dynamiclib ./frmts/o/*.o ./core/*.o ./port/*.o ./alg/*.o ./ogr/ogrct.o
./ogr/ogr_opt.o ./ogr/ogr_fromepsg.o ./ogr/ogrutils.o ./ogr/ogr_srs_proj4.o
./ogr/ogrsf_frmts/generic/ogrregisterall.o ./ogr/ogrfeaturestyle.o
./ogr/ogrsf_frmts/ogrsf_frmts.a ./gdal.a ./ogr/ogr.a ./gdal.a ./port/cpl.a
-lz -lm -L/usr/local/lib -lm -o ./libgdal.1.1.dylib
ld: common symbols not allowed with MH_DYLIB output format
./ogr/ogr.a(swq.o) definition of common _swq_error (size 1024)
/usr/bin/libtool: internal link edit command failed
make: *** [force-lib] Error 1
