[mapserver-users] truetype weirdness
Frank Koormann
frank.koormann at intevation.de
Mon Jan 7 11:40:50 EST 2002
Thorsten, All,
* thorsten fischer (thfischer at mapmedia.de) [020107 15:40]:
> > Did you recompile your own GD on a system that already came with GD
> > preloaded in the system libs by any chance?
> I did indeed recompile gd, as well as everything else. But as gd comes
> only as a static library in its Makefile configuration by default, it
> should not care about any system libs at that point. Therefore invoking
> 'ldd' does not show any reference to libgd (it is part of the
> executable).
> > You might want to use 'ldd mapserv' to double-check that the right copy
> > of gd and of the supporting freetype get picked. That's the best I can
> > think of... this really looks like a system configuration issue.
> It looks for me that way too. But: it happens on clean out-of-the-box
> installs of SuSE 7.3 too. No comments on pros and cons of that distro
> please ;)
> There is a patch to make gd compile as a shared library; i am trying to
> apply it to my own patches i use (because of the broken paths that live
> in the gd Makefile) and recompile; i will let you know what happens.
>From your post it is not clear to me what versions of gd and freetype
are running. So a blind shot:
- MapServer 3.5 need a 1.8.x version of gd (at least my experience was
to get positive results with 1.8.4).
- Within your gd directory there should be a tool gdtestttf
(Does it run successfully?)
Just some thoughts,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
