[mapserver-users] php_mapscript.so linkage problem?
Antti.Roppola at brs.gov.au
Wed Jan 9 21:48:31 EST 2002
It got the same problem. I kludged around it by creating a symlink
in the expected location to the actual location on my system, on the
assumption that it'll be ironed out eventually.
Have a look at./Zend/Makefile where EXPANDED_EXTENSION_DIR is set
and ditto for ./TSRM/Makefile. In the shorter term, you could edit
these Makefiles manually before running make.
It is being read at line 55098 in ./configure from the Zend source,
$ZENDSOURCE/Zend/zend_modules.h "#define ZEND_MODULE_API_NO". You
could also fiddle things here.
Sorry if this reads as a brain dump, but I am expecting this problem
to eventually go away and haven't thought it through much. :o)
Cheers,
Antti
-----Original Message-----
From: Doyon, Jean-Francois [mailto:Jean-Francois.Doyon at ccrs.nrcan.gc.ca]
But when I try to use dl() just before the phpinfo() I get:
Warning: Unable to load dynamic library
'/usr/local/lib/php/extensions/no-debug-non-zts-20001222/php_mapscript.so'
