[mapserver-users] Feature query with gml return
    Steve Lime
    steve.lime at dnr.state.mn.us
    Tue Jan 22 08:57:28 PST 2002
What Stephen did is all you need to do to a URL, however you need to add
one new parameter to the layer in your map file. That parameter is
called DUMP and by default it is set to FALSE. This is to prevent the
wholesale download of your data. The interpretation of this parameter
may change over time to allow attributes only or points only but for now
it's all or nothing.
The MapServer demo has been outfitted with a GML download option. It's
enabled if you have WMS enabled.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Stephen Woodbridge <woodbri at swoodbridge.com> 01/21/02 08:03 AM >>>
Trem,
I changed your URL  so it ended with INFO_FORMAT=GML and it spit back a
gml header, but the actual query results seemed to be missing but I
think this is "HOW" you would go about doing it.
-Steve W
> Trem Stamp wrote:
> Hi all,
> I posted a query regarding feature info and the return of gml for a
> feature recently.
> I have since got the stable build for mapserv3.5 (Solaris) compiled as
> of December 18th, which I understand has the ability to return gml.
> My feature retrun still seems to ignore the template file however and
> just return text.
http://maps-dev.socialchange.net.au/cgi-bin/mapserv?map=mapfiles/environmental.map&WMTVER=1.0.0&SRS=EPSG%3A4202&REQUEST=feature_info&LAYERS=estates&QUERY_LAYERS=estates&BBOX=140.08099999999996%2C-39.1493%2C154.753%2C-24.4773&WIDTH=400&HEIGHT=400&STYLES=&X=283&Y=234&INFO_FORMAT=MIME
> Is there anything I'm missing?  Does anyone have a working example of
> this?
> Cheers,
> Trem
More information about the MapServer-users
