[mapserver-users] Intercepting Map Click Coordinates withJavaScript ? Zooming with scale values.
Vladimir Guzmán
vguzman at bigfoot.com
Tue Jan 22 13:06:14 EST 2002
Hello.
I've been working on this for a while, and actually I can make it work in
IE 5+ and in Netscape 4. Actually I'm working on make it work with
Mozilla/Gecko browsers. I can do it with a tool I've found in
http://dynapi.sourceforge.net/dynapi/
called DynApi.
You can try my site in
http//200.24.94.114/ifx/
login test
password test
It is an application to manage ISP's coverages, so we can view, edit,
delete and update
clients, nodes and antennas on line. It includes a geo-coding algorithm.
It was designed for Bogota - Colombia - S.A.
If you have questions on how I've done, I'll be glad to answer.
Vladimir Guzmán R.
www.main-task.com
Stephen Woodbridge wrote:
>Well yes it IS darn near impossible! I got it to work for NS4 and IE4
>but I never played with it to get it to work on IE5 or NS6. Check out:
>http://web-maps.org/RQ/nav_map.php3?event=get_map&clat=42.634735&clon=-71.390831&zoom=8&title=North+Chelmsford%2C+MA+01863
>and run the cursor over the map and read the lat/lon in the boxes below
>the map.
>Let me know if anyone is interested in trying to get it to work with IE5
>and NS6 or adding it to a navigation Skin.
>-Steve W.
>Steve Lime wrote:
>>Does this actually work? I was under the impression it would IF the
>>image in question was in an absolutely positioned layer or it's own
>>frame. It's typically easy to get page coordinates but figuring out
>>where an image lies on the page (so you know where you are in the image)
>>is darn near impossible without layers or frames.
>>Steve
>>Stephen Lime
>>Data & Applications Manager
>>Minnesota DNR
>>500 Lafayette Road
>>St. Paul, MN 55155
>>651-297-2937
>>>>>Walt Lin <joemayfair at usa.net> 01/21/02 12:18 PM >>>
>>With CGI, it's dirt easy-- the input type=image automatically sends
>>along name.x and name.y as cgi parameters. So if you could do what you
>>want to server side, that's the most reliable and the easiest.
>>If you must do it client side, you could do something like this:
>>var mouseX=0,mouseY=0,setX=0,setY=0;
>>function getMousemove(e){
>> mouseX= (bw.ns4||bw.ns6)? e.pageX:
>> bw.ie&&bw.win&&!bw.ie4? (event.clientX
>> -2)+document.body.scrollLeft : !bw.opera5?
>> event.clientX+document.body.scrollLeft :
>> (event.clientX-2);
>> mouseY= (bw.ns4||bw.ns6)? e.pageY:
>> bw.ie&&bw.win&&!bw.ie4? (event.clientY
>> -2)+document.body.scrollTop : !bw.opera5?
>> event.clientY+document.body.scrollTop
>> : (event.clientY-2);
>>where the bw is browser detection stuff.
>>On Mon, Jan 21, 2002 at 11:38:36AM -0500, Doyon, Jean-Francois wrote:
>>>Hello,
>>>This is not necessarily a mpaserver specific question but ...
>>>Is there anyway/does anybody know how to intercept the x/y pixel
>>coordinates
>>>that the user generated by clicking on the map when using the map as
>>an
>>><input type=image> ?
>>>I'm trying to create an interface that uses scale values to determine
>>the
>>>next up/down zoom levels, and apparently in order to do this I have to
>>use
>>>the CGI variable MAPXY, which unfortunately has to be inn the map's
>>>projection coordinates.
>>>So, I need to intercept the pixel coordinates (img.x and img.y) in
>>order to
>>>do the necessary calculations and set MAPXY, all this triggered by the
>>>form's onSubmit ...
>>>Anybody have any idea on how to do this? I haven't had any luck so far
>>using
>>>things like document.form.img.x ...
>>>If worse comes to worse I guess I could use client-side maps, but I'd
>>rather
>>>not unless I absolutely have to!
>>>Thanks in advance for the help!
>>>Jean-Fran?ois Doyon
>>>Internet Service Development and Systems Support
>>>GeoAccess Division
>>>Canadian Center for Remote Sensing
>>>Natural Resources Canada
>>>http://atlas.gc.ca
>>>Phone: (613) 992-4902
>>>Fax: (613) 947-2410
